Amplifier istall in GMC Sierra
Old Jan 9, 2006 | 06:07 PM
9GMC9's Avatar
Default Amplifier install in GMC Sierra
I want to install an amplifier for my new sound system in my 99 Sierra. So would I connct the power wire that goes to the amp on the battery possitive that is in the little red box? Or the battery?
Old Jan 9, 2006 | 07:40 PM
TXsilverado's Avatar
either one will work, but the red box is easier to access.
Old Jan 9, 2006 | 08:09 PM
9GMC9's Avatar
Alright thanks, so either one will be ok.
Old Jan 10, 2006 | 09:21 AM
el_cabby's Avatar
red box por favor
Old Jan 10, 2006 | 09:35 AM
Fogle07's Avatar
i put mine in that fuse box under the hood by the battery. there is a bolt there where you can hook a wire to and all youll have to do is put a fuse in the empty slot. ill go take a picture of a truck at lunch to show you where it is. in my opinion it looks 100 times cleaner because you cant see the wire because it is covered by the black cover and it comes out right there where you stick it into the cab.
Old Jan 10, 2006 | 12:55 PM
Fogle07's Avatar
heres some pictures. the first one is of my uncles 05 silverado. it has the smaller fuses in it. the thing circled is just a plug. take that out and get you a fuse the size you want and put in there. if you take that black cover off theres a stud in there with a nut on it. its not used for anything on a gas truck so you can just bolt your + cable on there.
these next 2 pictures are out of a duramax thats why there is a fuse in the slot. this is what the 99-02 trucks fuse box looks like i believe.
Old Jan 11, 2006 | 05:26 PM
TIM Z's Avatar
11 sec. Truck Mod
great idea fogle!! i think ill borrow that tip my self!
Old Jan 12, 2006 | 12:33 AM
smooth_addictions's Avatar
the yellow wire isnt your power is it?
Old Jan 16, 2006 | 11:19 PM
retsell's Avatar
This will work ok for small amps, but if you are using anything bigger than 10 guage I would recommend running the power to the battery (not the fuse box or red jump box) as larger amps will draw a lot of current. Remember, the fuse box is only fed by a single 8 guage cable running all your factory accessories. If you're running 4 guage to an 8 guage feed you are wasting your money and causing current issues. Also the red box is running from a 4 guage feed off the battery and you are introducing multiple connections between your amp and the battery.
Going to the battery is always the best option, but you can get away with others sometimes.
Old Jan 16, 2006 | 11:44 PM
Going to the battery is always the best option, but you can get away with others sometimes.[/QUOTE]
i agree!!! small amps you will be cool other than that you are shooting your self in the foot. the red box will work fine!!
