Amp question, keeps turning off
Old Oct 19, 2005 | 07:20 PM
SweetNslow's Avatar
Default Amp question, keeps turning off
Hey guys. I got a JL 500/1 amp and ive been having some trouble with it. The thing is about 4 years old and it has started to cut off when i turn my volume up . Now it is not turning on at all, but it is getting juice. Does anyone know what this could be or what is causing it. Any help would be great, thanks....
Old Oct 19, 2005 | 07:22 PM
BradS's Avatar
It might be overheating. Check to see if the fan is blowing.
If its not blowing you might have burned it up. How many and what size speaker did you have on it?
Old Oct 19, 2005 | 07:58 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Check your remote wire also it could be loose are it may have been cut from rubbing on something for so long. Take a voltage tester with the radio on and check the remote terminal and make sure it has power.
Old Oct 19, 2005 | 08:05 PM
SweetNslow's Avatar
Its getting power from the wires, i even checked the remote, but the amp is just not turning on. Before it would at least turn on and run till i turned the volume up and then cut off. I will check and see if the remote wire is still intact, that sounds like a possible scenario. Thanks
Old Oct 19, 2005 | 08:22 PM
bluecajun5.3's Avatar
11 Second Truck Club
i had this happen to me before. change the rca jacks. they do go bad.
Old Oct 19, 2005 | 08:58 PM
check all what was posted up then check for shorts. but if it is not popping the fuse you should be ok.
Seth
Old Oct 19, 2005 | 09:40 PM
TXsilverado's Avatar
make sure the speaker wire hasnt freyed out and touched the casing of the amp. thats what mine did. i would barely turn it up and it would cut off. looked at what was going on and one lil frey of the wire was touching the metal on the amp case and was putting it into protection mode when i fed it any juice.
Old Oct 21, 2005 | 01:22 AM
1badgmc's Avatar
Yea I had problems with my remote wire up under my carpet . It was frayed from being under ther so long. It was a PITA to find the problem but that's what ya get for not taking time when runnin wires.
Corvette454l88
Sep 1, 2016 01:24 AM
Bluchevypick
Aug 18, 2015 09:11 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
slowlsx
Jul 13, 2015 04:18 AM
