amp power wire to battery terminal
Old Jun 13, 2007 | 05:21 PM
dropkick13's Avatar
Default amp power wire to battery terminal
how are you guys hooking your power wire to the battery? i can't seem to thread the bolt if i add the ring terminal...its not long enough. should i get a longer bolt? do they have these special bolts at home depot?
Old Jun 13, 2007 | 05:35 PM
thunder550's Avatar
High on diesel fumes
You can get longer bolts for the GM side post batteries at most audio shops.
Old Jun 13, 2007 | 07:44 PM
87XJRob's Avatar
I just notched the little red battery box where the Alternator ties in and came up from the bottom with my 4-guage
Old Jun 13, 2007 | 08:13 PM
truckmann's Avatar
I just ordered some nice Monster connectors from ebay to use on the post connectors on top of the battery. Of course that only works if you have a battery with the posts and side connectors. Here are some pics I took for something else but you can kind of see what I got going on.
Old Jun 13, 2007 | 11:04 PM
53bowtie's Avatar
you can get a battery tap at best buy, oriellys, auto zone etc. fot the side battery posts.
Old Jun 14, 2007 | 02:35 AM
nicks05z71's Avatar
x2.....
Old Jun 14, 2007 | 05:13 AM
lawson4450's Avatar
i got a two bolt set up the one bolt goes into the battery and then there is a second bolt that goes inside that where the cable is connected
05GMC4.8
Aug 7, 2015 09:55 PM
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
bsgiffor
Jul 19, 2015 11:14 AM
