amp ?
a friend of mine thats into car audio is gonna put 2 10" kicker L7 subs behind the seat of his reg cab silvy and wants to know what kind of amp he needs
also wants to know if he needs a two channel to run two subs or not
it takes 1200peak watts and 600 RMS watts to run EACH sub and he wants 1 amp to run both subs
any help is apprecciated
what he is going to do is order all parts himself and go have them all installed
A monoblock amp would be a good idea for that setup. Check out www.the12volt.com for a lot of good info on that kind of stuff.
yall are telling me a 1000watt amp is enough to pull both subs and he need 1200watts for the rms rating on them and they can pull up to 2400 watts together or am i way off
also is memphis better than JL i always thought JL was hot **** he just wants something that wont fry them subs but at the same time gives them all the power they need and he wants a national brand
The peak power rating is virtually meaningless. It is just a rating that helps manufacturers sell their product, what is important when choosing the right subs or amp is the RMS (root mean square) rating. This is basically the wattage used by the sub at a continuous rate. Also if those are rated at 600W RMS you really don't want to under power them, if you run like a 400 watt amp to them it will do more harm than good in the long run eventually ruining them. The reason being is the amp will try too hard to produce the power needed and start clipping ( almost like distorting ) and damage the voice coils. Now I know this sounds weird but it is better to over power a speaker. I am running an Infinity 611A amp which produces like 500W RMS to one 12" Infinity Perfect that is rated at 350W rms and it sounds super. Just remember, the more power the better the sound quality.
