aftermarket alarm + interface and door locks arn't working
Old Feb 27, 2012 | 04:52 PM
TXjeepTJ's Avatar
Default aftermarket alarm + interface and door locks arn't working
I installed a ScyTek Astra 4000RS alarm
ScyTek Astra 4000RS-2W Remote Start 2-Way Car Alarm
and bought this interface
Omega DB-GMDLBP (dbgmdlbp) Databus Doorlock, Alarm, and Passkey/
I hooked everything up, and programmed the interface, but all the door locks still do not work with the aftermarket alarm fob
is there another process I have to do? Such as de-programming the stock key fob or something?
Old Feb 27, 2012 | 09:28 PM
TXjeepTJ's Avatar
could it have to do with me having VATS removed from the PCM?
wires that I do not have hooked up to the bypass module are
door trigger output
dome light input
wires that are not connected on alarm side
factory disarm (module should do this..)
dome light
door input
the unlock/lock function is going from the alarm to the bypass module.. which should be sending a signal through the data bus....
chopperloco
Jul 10, 2016 10:45 PM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
