aem uego issues
whats goin on everyone...havin some issues with my wideband and figured id ask here to see if anyone had any advice. ive got the uego gauge and its been stuck at 14.7 for quite some time, guys said if theres a bad connection or pinched harness itll be stuck...well just replaced the guage to sensor harness everythings hooked up properly and still no luck. could it be the sensor being that fouled out? any help would be greatley appreciated!
thanks in advance
tj
thanks in advance
tj
latley UEGO started ti have some issues, if its stuck @ 14.7 that mean no signal from the sensor, OR the same thing happed to me,,keep it hooked and over time (30min) it will start to read slowly and gain speed.
in short contact AEM if the same thing happend to you.
now go and buy an FJO WB
this guage is probably 2years old if even but thats interesting to hear your havin the same problem, but that new touch screen wb is pretty dirty. im thinkin it may be time to part with the uego specially when its been causing nothing but issues
i was trying to do that the other day but unfortunitley the wb sensor is stuck in my ypipe, so as soon as i can get that out i will for sure test it. as of last night with my rear end and possible trans letting loose this sensor is starting to be the least of my worries. thanks for the feed back though its much appreciated!
TAPyvehc93
Sep 14, 2015 01:22 PM
