4 12's in a crew cab
Old Feb 24, 2007 | 07:53 PM
Budman52tx's Avatar
Default 4 12's in a crew cab
Just got 4 kicker comp 12's in the truck i am running a kicker 650x1 digital amp. has anyone heard of putting pillow filling in the bax to kinda create more air space for the deeper bass?
Old Feb 24, 2007 | 07:56 PM
2004SSS's Avatar
its called polyfil .
Old Feb 25, 2007 | 04:43 PM
SmokedSierra01's Avatar
Yea that is a possibility, but you are running some serious power. You subs may have that polyfil in there, but you need to make sure and get maximum airspace for those things to really pound
Old Feb 25, 2007 | 09:14 PM
spitfire2332's Avatar
kicker calls for 1.25 cubes minimum for a comp 12. You'd be better off running 2 12" CVRs than 4 comps IMO.
Old Feb 28, 2007 | 07:20 PM
Budman52tx's Avatar
i went and bought some of the polyfill the box has a 1 cu. ft per sub so...hopefully it will be better with the polyfill
Old Mar 13, 2007 | 08:44 PM
Budman52tx's Avatar
that stuff does make a differance very noticable thanks alot
Old Mar 14, 2007 | 08:21 PM
1SlowHoe's Avatar
Destroyer of Transmissions
That amp is only stable at 2 ohms right? How are you running 4 subs on it?
Running them parallel or in series?
Old Mar 14, 2007 | 09:15 PM
Budman52tx's Avatar
i wired them all into one and then to the amp it is 2 ohm stable it is the sx 650.1
Old Mar 14, 2007 | 09:17 PM
are they dual 2ohm or 4ohm subs?
Old Mar 14, 2007 | 09:35 PM
Budman52tx's Avatar
single 8 ohm
