145 amp alternator
Old Feb 9, 2009 | 02:21 PM
Wyttrash96's Avatar
I hate my cats
Default 145 amp alternator
I'm getting ready to install LS1 fans in my 99 Sierra. I've got a 145 amp alternator to replace the original 105 amp job. The regulator pigtail for the 145has 2 wires as opposed to the single wire on the 105. Should i just solder them together and join them up to the harness wire? Thanks.
Old Feb 9, 2009 | 08:26 PM
budhayes3's Avatar
PT's Slowest Truck
I'm not sure, but you may not need the 2nd wire, I believe that it is for a PCM controlled duty cycle for newer year vehicles. I had to run a wire from the PCM to the alt when I swapped in an 02 PCM into my 99, so if you're only changing the alt (and not the PCM), you "should" be OK
Old Mar 9, 2009 | 08:02 PM
gxrior's Avatar
Default Nations alternator.
Google Nations Alternator.
You can call or E-mail them.
They will have an adapter or tell you what you can do to make it work.
Old Mar 9, 2009 | 09:58 PM
53bowtie's Avatar
I dont believe you need to do anything. I had a local shop build me a 200amp alt out of a 145 housing and I just plugged it straight in with my existing plug from the old 105amp alt.
Texas5.3_1251
Mar 5, 2016 08:10 PM
drummer0415
11
Oct 24, 2015 08:16 PM
CD82
Oct 23, 2015 07:32 AM
Dawas
Sep 20, 2015 12:00 PM
