'03 Instrument Cluster
Old Jul 29, 2019 | 11:15 AM
ss4chad's Avatar
12 Second Club
Default '03 Instrument Cluster
When I start my truck, the instrument cluster takes about 3 to 5 seconds before it comes to life, its totally blank. Scrolled thru here looking for a similar issue, didn't find a post with a similar issue.
I turn the key to the start position, here the fuel pump running, see lights in the cluster lit but when I start it the lights go out, the gauges go limp and there is a black screen while the truck is running. After about 2 - 5 seconds the lights come on, the gauges flash and everything comes to life showing fuel, oil, temp and volts.
Is my cluster going out? Or am I stuck in a time & space continue'um floating in dark matter for that brief moment in time? Could it be those old coke days are coming back to haunt me? Maybe the bong resin is finally getting gooey enough to make my mind stick for a brief moment?
Wait, why am I here again? Was there a BBQ chicken recipe I'm supposed to get?
Chad
Old Jul 30, 2019 | 08:15 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It's probably got a bad solder joint. Does it go dead any other time?
Old Jul 31, 2019 | 07:55 AM
ss4chad's Avatar
12 Second Club
Nope, just on start up. I turn the key to the "ON" position, hear the fuel pump running, turn to start and the engine turns - fires - and is running while the cluster is blank, then within a couple of seconds it all comes to life with all gauges reading.
Weird.
Chad
Old Jul 31, 2019 | 08:22 AM
madmann26's Avatar
How many miles? Sounds like rebuild time.
Old Jul 31, 2019 | 01:04 PM
ss4chad's Avatar
12 Second Club
237,358 miles on the cluster. Never been touched.
Chad
Old Jul 31, 2019 | 01:07 PM
madmann26's Avatar
Going to PM you.
Old Aug 1, 2019 | 12:07 AM
skolman91's Avatar
Give it a quick love tap with ur fist and i bet it turns on, solder issues like mentioned theyre pretty common..
Old Aug 1, 2019 | 09:01 AM
ss4chad's Avatar
12 Second Club
Thanks Madmann, got the contact info!
Chad
Old Aug 1, 2019 | 09:03 AM
ss4chad's Avatar
12 Second Club
Thanks Skolman, I will give it a tap. If that works then like you said, I got physical issues that will need to be fixed. Cheers!
Chad
Old Aug 11, 2019 | 07:47 PM
BIG_MIKE2005's Avatar
12 Second Club
Man from what I have read these clusters can cause a few different issues once they develope a problem in the solder. I just had mine completely rebuilt and gone thru for my 04’ for $140.
ThunderZ28
Aug 3, 2004 12:09 AM
Black Sunshine/ 00SS
Nov 23, 2003 08:48 AM
Alex D
19
Dec 31, 2002 01:45 PM
Alex D
Dec 9, 2002 08:24 PM
Neil 6.0
11
Apr 25, 2002 03:32 PM
