'00 Silvy Remote Start Alarmm Install Help
Old Dec 29, 2011 | 07:10 PM
Velocity1's Avatar
Default '00 Silvy Remote Start Alarmm Install Help
What's the easiest way to access the ignition wires under the dash? I already found out the chassie module slips out of it's bracket and will hang down out of the dash. (Purple, Blkue and Brown plug harnesses).
Where are the rest of the ignition harness wires? Are they marked? Loomed or do they run to the driver side kick panel?
This job would already be done if I could find these wires.
Thanks.
Old Dec 30, 2011 | 11:36 PM
Velocity1's Avatar
Anybody?
Old Jan 1, 2012 | 08:11 AM
musclecity85's Avatar
the wires and ignition harness should be under the steering column where the key is..you have to take the plastic trim piece underneath the steering wheel out and you should be able to access them easily
Old Jan 2, 2012 | 08:30 AM
Velocity1's Avatar
Happy New Year and thanks for the reply. I don't have the FSM for my truck. is the plastic trim piece held in place with clips of some sort of fasteners?. It's difficult for me to look and see. I've got limited neck mobility. Of course I could use a mirror, but I don't want to risk breaking anything if I can avoid it. I'll take all the help and advice I can get.
Thanks, V1
Old Jan 8, 2012 | 09:56 PM
Velocity1's Avatar
I'm trying to locate them where they come out of the end of the column under the dash. I had the "BCM" module out, (The one with the 3 plugs that control windows, factory options, etc.). Didn't see any sign of them unless I was looking right at them and didn't realize it. Is there any chance they terminate in the driver side kick panel?
Really, if I can find the ignition harness bundle I can have this alarm / remote start operational in probably no more than an hour or so. It was custom engineered/built specifically for my truck. Each of the control module wires splice into my 2000 Z71 electrical harness wires which are extremely well defined in the vehicle specific instructions.
Any further help/advice would be appreciated.
Thanks, V1
shawn96gmc
May 17, 2016 04:15 PM
BKnBLK05
Dec 28, 2015 08:52 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
