'00 Silverado Console Removal?
Old Jan 2, 2012 | 07:27 PM
Velocity1's Avatar
Exclamation '00 Silverado Console Removal?
Haven't had any hits in the searchg function. Can anyone point me to a console DIY link? I'm installing a powered sub under the back seat and want to use the space between the console and cab floor to route the wires.
Appreciate any help.
Thanks, V1
Old Jan 2, 2012 | 08:04 PM
Mangled03gmc's Avatar
Baltimore Whore
Driver or passenger seat has to come out completely. The wires/harness are plugged in under there some place..
Old Jan 2, 2012 | 08:35 PM
Velocity1's Avatar
I'm thinking I'm going to run the RCA L/R amp feeds from the head unit back to the amp/woofer, and the wired remote control back up front to a panel where the original cassette player is. And I have to remove one of the seats to do this? It's a 2000 Silverado Z71 extended cab. Am I missing sonmething? The battery power feed will run down the left door sill under the carpet after I grommet it through the firewall. The ground will be made under the seat at the amp at one of the seat mounts. I want to pull the console out regardless.
Thanks
Old Jan 2, 2012 | 08:42 PM
Baltimore Whore
Yes to get console out both seats have to be unbolted.. One has to come out the other just lifted up to get the console brackets off the seat posts. If it has a heater control or factory sub in it, the harness needs to be un plugged.. That is the same way I ran my RCA's and remote wire, along with the power wire under the left side sill panel around to the amp, also grounded to a seat bolt..
Old Jan 3, 2012 | 12:09 AM
Velocity1's Avatar
Roger that. I saw the pic of the ''03 console for sale. Can't believe they tied it into the seat studs. Guess I'll pull the seats. Can't wait. Got half a mind to drill holes through the console and run the wires through a false bottom and under the rear carpet through a razor slit under the rear bench to avoied all they work...lol...I still want to pull the OEM Cassette player and create a space for utilities and/or CB. Gotta think on this one....
Old Jan 3, 2012 | 12:45 AM
Baltimore Whore
Here is a console I put in my truck, orig had the flip up center seat.. Just to give ya a idea of it..
https://www.performancetrucks.net/fo...w-pics-477031/
Old Jan 3, 2012 | 12:09 PM
Velocity1's Avatar
Very sharp. Nice work.
zblee
63
Jun 10, 2023 01:25 PM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
My72olds
Jul 10, 2015 11:26 AM
My72olds
Jul 10, 2015 08:29 AM
