Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Gears, Posi's, Lockers, Bearings, Axles, More!
Old Jul 2, 2013 | 10:41 AM
  #531
RONS MACHINING SERVICE's Avatar
FormerVendor
Originally Posted by ShredSled
Also interested in cost of Eaton LSD and wondering if you have them with the 800# springs too?
PM sent, we can offer the standard eaton lsd but not with 800# springs.
Thanks
Old Aug 30, 2013 | 11:30 PM
  #532
Just picked up a 2008 GMC Sierra SLE regular cab short bed 2wd... GT4: rear axle with 3.73 gears... The rear is howling and I don't want to rebuild the factory carrier....
Looking at the Detroit Truetrac 913A481...
Also, an install / bearing kit?
Ship to Dallas 75209?
Old Sep 3, 2013 | 12:32 PM
  #533
FormerVendor
Hello, no problem, here are the links:
GM 8.5 Detroit Truetrac Posi Differential 30 Spline 913A481 - Ron's Machining Service
1999-2008 GM 8.6 Master Install Bearing kit ZK GM8.6 - Ron's Machining Service
Free Shipping. Thanks!
Old Sep 3, 2013 | 07:33 PM
  #534
Evictor's Avatar
Detroit locker for 14 bolt and 4.56 gears front and rear + install kits truck is a 2013 4wd 1500 silverado 6.2 with 7000 miles.
Old Sep 5, 2013 | 01:50 PM
  #535
FormerVendor
PM sent, Thanks!
Old Sep 5, 2013 | 10:21 PM
  #536
needmorepewter00's Avatar
Price on a Tru Trac, 3.73 Ring and Pinion, and an install kit for 2004 silverado 8.6 please
Old Sep 8, 2013 | 09:48 AM
  #537
FormerVendor
1999-2008 GM 8.6 Truetrac Posi 3.73 Excel Gear Package - Ron's Machining Service
$680 delivered (48 states), Thanks!
Old Sep 9, 2013 | 12:29 AM
  #538
La MaXxImUs PrImE's Avatar
Could i get price for 4.56 gears for a 14 bolt gm rearend for my 08 vmax and anything else needed...already have a truetrac. Thanks
Old Sep 10, 2013 | 12:24 PM
  #539
FormerVendor
Hello, no problem. Do you know which size 14 bolt?
Thanks
Old Sep 11, 2013 | 01:49 AM
  #540
1FastBrick's Avatar
Custm2500's Rude Friend
Thanks
FWI, the Vmax option has a 14 bolt 9.5 under RPO code AXN.
Option code AXN will use the standard newer style 9.5 carrier parts but has 10 bolt axle bearings.
I would like to know if you have a master install kit for a 2000 Chevy Silverado GMT 800 10 bolt 8.6 rear end with axle bearings and seals??? What brand would the bearings be???
Also do you sell the Eaton Posi for the same rear end??? Would you recommend keeping the standard 400 Lbs Springs or go with the 800 Lbs Springs???
This is a daily driver with mild performance. Only driven on the street, No burn outs, but occasionally driven hard.
Can you quote that with a T&A cover and Cap Studs???
I already have gears.
Thanks!
