Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Gears, Posi's, Lockers, Bearings, Axles, More!
Old Sep 11, 2013 | 10:20 AM
  #541
RONS MACHINING SERVICE's Avatar
FormerVendor
FWI, the Vmax option has a 14 bolt 9.5 under RPO code AXN.
Option code AXN will use the standard newer style 9.5 carrier parts but has 10 bolt axle bearings.
I would like to know if you have a master install kit for a 2000 Chevy Silverado GMT 800 10 bolt 8.6 rear end with axle bearings and seals??? What brand would the bearings be???
Also do you sell the Eaton Posi for the same rear end??? Would you recommend keeping the standard 400 Lbs Springs or go with the 800 Lbs Springs???
This is a daily driver with mild performance. Only driven on the street, No burn outs, but occasionally driven hard.
Can you quote that with a T&A cover and Cap Studs???
I already have gears.
Thanks!
PM sent, Thanks!
Old Sep 12, 2013 | 10:01 AM
  #542
La MaXxImUs PrImE's Avatar
Originally Posted by RONS MACHINING SERVICE
Hello, no problem. Do you know which size 14 bolt?
Thanks
I believe its a 9.5" but id be lying if i told you i was 100% sure...my truck is a 2008 2wd silverado 1500 2wd that came with 4L70 tranny and 14 bolt rear end... From what ive read i think its 9.5"
Old Sep 13, 2013 | 12:26 PM
  #543
FormerVendor
Here are a couple of links:
*GM 9.5 Chevy 14 Bolt 4.56 Ring and Pinion USA Standard Gear ZG GM9.5-456 - Ron's Machining Service
*GM 9.5 Chevy 14 Bolt Master Install kit 1998-Newer ZK GM9.5-B - Ron's Machining Service
Thanks!
Old Sep 13, 2013 | 03:47 PM
  #544
Great thanks alot ive been looking for this for awhile but kept getting confused...out of curiousity is there really a big difference in the yukon bran and the other? Im placing an order next friday so want to make sure
Old Sep 16, 2013 | 12:39 PM
  #545
FormerVendor
No problem. Yukon is normally the quietest running gear.
Thanks
Old Oct 1, 2013 | 03:54 PM
  #546
Chevy-Fun's Avatar
1984 c10 10bolt believe it has 2.73 gears GU2. wanting posi an 3.73. on your website you have richmond yukon, an yukon usa standard. whats the difference. price/shipping to 76014.
Old Oct 2, 2013 | 09:12 AM
  #547
Noah Burns's Avatar
your site wouldn't pull up for me on my phone... do you carry rear diff girdles... 2008 1/2 ton silverado?
Old Oct 4, 2013 | 09:03 AM
  #548
FormerVendor
Hello, here is a link to a premium gear package for your application:
GM 8.5 Posi 3.73 Excel Gear Package 28 Spline 1972-1987 - Ron's Machining Service
Thanks, Ron
Old Oct 4, 2013 | 09:04 AM
  #549
FormerVendor
Hello, yes, if your truck has a 10 bolt rear. We have the TA performance cover for $155.00.
GM 8.5 Chevy 10 Bolt Low Profile TA Performace Cover/Girdle TA 1807A - Ron's Machining Service
Thanks, Ron
1-800-694-3098
Old Oct 8, 2013 | 12:53 PM
  #550
GONZALESS's Avatar
Hey ron iwas looking in your website and coulndt find a package for a trutrack with 3.90 gear. Already have the install kit. Could u quote me a price for that. And also some cap studs. Thanks.
