Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
B-day, Turbo kit special, New 1800.00 kit..
Old Feb 10, 2011 | 11:38 AM
TrickTurbo's Avatar
Truck Sponsor
Default B-day, Turbo kit special, New 1800.00 kit..
Special on turbo kits. We need 5 customers to make this killer deal happen.
These non-inter cooled kits are very good enter level boost applications. Inter-cooler upgrades are available for 650.00. Our inter-cooler kits have the shortest aluminum pipe routing in the industry. Can be maf or maf-less.
Comes with bead rolled ends, standard.
Prices + freight and or fees.
PM me if I can help you get into boost, or if you have any questions.
Rick
You have 3 options as far as the kits go.
Standard, Mandrel, and Stainless.
Standard: 1800.00
Years 99-11 trucks,
MP70MM turbos,
Swept runner thick wall manifold
38mm gate, vented to atmosphere
44mm blow offs,
oil pressure and return lines
3" down-pipe, crinkle bent
2.5 crossover, crinkle bent
aluminum cold pipe
black silicone couplers and ss clamps.
Here's the pic of this kit.
and installed.
Mandrel option. 2200.00
Years 99-06
MP70MM turbos,
44mm blow offs,
3" down-pipe aluminized MANDREL BENT
2.5 crossover,aluminized MANDREL BENT
aluminum cold pipe
IF you added the intercooler upgrade your kit will look a lot like this.. pic has lots of extras. use it for referencing the IC only.
Stainless Option. 2500.00
Years 99-06
MP70MM turbos,
44mm blow offs,
3" down-pipe Stainless Steel MANDREL BENT
2.5 crossover,Stainless Steel MANDREL BENT
aluminum cold pipe
IF you added the intercooler upgrade your kit will look a lot like this.. pic has lots of extras. use it for referencing the IC only. and piping will be swapped to stainless steel.
07 inter-cooler kits can be built but at an added cost.
Old Feb 10, 2011 | 12:41 PM
TIM Z's Avatar
11 sec. Truck Mod
Nice looking kit and great prices!!!
You and KB have the nicest kits ive seen anywhere!
I need to put one on the wifes, think she'd notice ?
Old Feb 10, 2011 | 02:01 PM
03sierraslt's Avatar
You need to leave your wifes ride alone before she beats you.
Old Feb 10, 2011 | 02:12 PM
fortplainman's Avatar
does that intercooler mount up next to the radiator or between the framerails? if its up with the radiator, will it fit with an enlarged trans cooler?
Old Feb 10, 2011 | 02:48 PM
iamkeniff's Avatar
i think you'd have to mount the "larger trans cooler" on the outside of the IC, so you would actually have to make new mounting tabs for the trans cooler.
this is just a guess, but im pretty sure it could work.
Tru-Cool 40k think it'd work with that?
Old Feb 10, 2011 | 03:23 PM
03tahoe22's Avatar
What yr make model are these kits for?
Old Feb 10, 2011 | 03:34 PM
TrickTurbo's Avatar
Truck Sponsor
Mounts between the frame rails. Earlier 99-02 have NO room infront of the the grill.. 03-06 has more, but its tight. 07+ have tons of room.
As long as the trans cooler was inside the A frame on the core support or .5" thick it will all fit in the 07+ trucks.
NON intercooled kits fits 99-11. Inter cooler options as priced fit the 99-06 truck.
Old Feb 10, 2011 | 03:45 PM
thanks for that info, looks like the intercooler would fit behind the grille of the 07+.
Old Feb 10, 2011 | 04:06 PM
TrickTurbo's Avatar
Truck Sponsor
Sorry the outlets are aim rearward. 07+ needs the outlets aimed out the sides.
Old Feb 10, 2011 | 04:22 PM
ah, id have to do some kind of thinking/find one that exits the sides. sorry for threadjacking good luck with your sale!
