B-day, Turbo kit special, New 1800.00 kit..
Special on turbo kits. We need 5 customers to make this killer deal happen.
These non-inter cooled kits are very good enter level boost applications. Inter-cooler upgrades are available for 650.00. Our inter-cooler kits have the shortest aluminum pipe routing in the industry. Can be maf or maf-less. Comes with bead rolled ends, standard. Prices + freight and or fees. PM me if I can help you get into boost, or if you have any questions. Rick You have 3 options as far as the kits go. Standard, Mandrel, and Stainless. Standard: 1800.00 Years 99-11 trucks, MP70MM turbos, Swept runner thick wall manifold 38mm gate, vented to atmosphere 44mm blow offs, oil pressure and return lines 3" down-pipe, crinkle bent 2.5 crossover, crinkle bent aluminum cold pipe black silicone couplers and ss clamps. Here's the pic of this kit. http://www.trickturbo.com/images/turbo/kit/stage1.jpg and installed. http://www.trickturbo.com/images/tur...stage1_top.jpg Mandrel option. 2200.00 Years 99-06 MP70MM turbos, Swept runner thick wall manifold 38mm gate, vented to atmosphere 44mm blow offs, oil pressure and return lines 3" down-pipe aluminized MANDREL BENT 2.5 crossover,aluminized MANDREL BENT aluminum cold pipe black silicone couplers and ss clamps. IF you added the intercooler upgrade your kit will look a lot like this.. pic has lots of extras. use it for referencing the IC only. :) http://www.trickturbo.com/images/tur.../stage3_lg.jpg Stainless Option. 2500.00 Years 99-06 MP70MM turbos, Swept runner thick wall manifold 38mm gate, vented to atmosphere 44mm blow offs, oil pressure and return lines 3" down-pipe Stainless Steel MANDREL BENT 2.5 crossover,Stainless Steel MANDREL BENT aluminum cold pipe black silicone couplers and ss clamps. IF you added the intercooler upgrade your kit will look a lot like this.. pic has lots of extras. use it for referencing the IC only. :) and piping will be swapped to stainless steel. http://www.trickturbo.com/images/tur.../stage3_lg.jpg 07 inter-cooler kits can be built but at an added cost. |
Nice looking kit and great prices!!!
You and KB have the nicest kits ive seen anywhere! I need to put one on the wifes, think she'd notice ?:devil: |
Originally Posted by TIM Z
(Post 4638989)
does that intercooler mount up next to the radiator or between the framerails? if its up with the radiator, will it fit with an enlarged trans cooler?
i think you'd have to mount the "larger trans cooler" on the outside of the IC, so you would actually have to make new mounting tabs for the trans cooler.
this is just a guess, but im pretty sure it could work. http://i33.photobucket.com/albums/d8...ff/cooler2.jpg Tru-Cool 40k think it'd work with that? |
What yr make model are these kits for?
Originally Posted by fortplainman
(Post 4639049)
Originally Posted by iamkeniff
(Post 4639068)
Originally Posted by 03tahoe22
(Post 4639103)
thanks for that info, looks like the intercooler would fit behind the grille of the 07+.
(Post 4639119)
ah, id have to do some kind of thinking/find one that exits the sides. sorry for threadjacking good luck with your sale!
