Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
wooops
Old Mar 7, 2007 | 03:26 PM
  #31
litreddevil's Avatar
Banned
Originally Posted by v8
then I would be a H/C N/A 5.3 and loose my title, damn it you guys are makeing it hard not to tell them to do it ahhhaa.
yea but you will then have a title that really be hard to break
i want you are lance to do something damn it i know if you'll do some type of head work you'll could get in the 11.s with a 5.3
Old Mar 7, 2007 | 04:12 PM
  #32
storm5.3's Avatar
13 Second Truck Club
Talking
Get 'em milled.. I'd do it and make sure they clean up the ports for ya and a slight 3 angle job too...You already got 'em off the truck...
Old Mar 7, 2007 | 04:20 PM
  #33
v8
17,16,15,14,13,12,11 Drvr
Originally Posted by La Chochita
I don't know if it's because of it, but I sure regret in doin' the millin on mine............
Months ago I had posted here about my second broken timing chain and bent valves, and I decided to do that while the heads were out.........:30' mill and mild pocket port.
Before this my trap speeds at hot weather were easily 106.highs, the highest that I had trapped was 106.998...almost 107.
Now, I'm barely trapping at 106's. My best so far has been a 106.058 and the other times have been 105.xx, including some 104's .............in cold weather so I am kind of dissappointed in that. Maybe you guys will think I'm wrong cuz logically it should help, but that's all I have done diffrent to her and well.......I sure regret in doing it.
It's not that I wanna break your bubble, Kev, but it's just something to think about.
one thing for you to check is the alighnment of the dots for the timeing chain, seems like you messed somthing up there, as far as milling a head higher compression should net faster and better times in the same DA, greggo lost time and mph with his dots not lined up only off 1/4" maybe not that much, open her back up and check everything, headers won't hurt you either so its all in the timing chain position I would think.
Old Mar 7, 2007 | 05:17 PM
  #34
La Chochita's Avatar
I really wish that would be it,....but I'm sure that it's not. And about the headers, that's why I would think that it would've run better nor not less...
If you do decide to do this, I really hope for you to get good results Kevin,.. .
I can't think of something else that can be affecting my truck's performance.
I know the power is good, 381 rwhp.........so then? .....I don't know .
Good luck with everything Kev!
Old Mar 7, 2007 | 09:17 PM
  #35
v8
Thanks, I chased down all the parts tonight and took them to the mechine guy(mr.Destiny) at harris mechine shop, they should be ready tomorrow and installed no later then friday.
Old Mar 8, 2007 | 11:53 AM
  #36
ThunderZ28's Avatar
12 Second Club
Kevin, did you get the gaskets????
Old Mar 8, 2007 | 11:54 AM
  #37
v8
No Thunder Racing has not sent them yet, ******.
Old Mar 9, 2007 | 01:06 PM
  #38
ThunderZ28's Avatar
12 Second Club
Kevin,
got the gaskets in hand..
$32
and also have the screws, and nuts you where talking about ..
Old Mar 9, 2007 | 02:10 PM
  #39
v8
cool see ya tomorrow!
TXsilverado
40
Mar 29, 2005 02:44 AM
