wooops
#22
Originally Posted by v8
then I would be a H/C N/A 5.3 and loose my title, damn it you guys are makeing it hard not to tell them to do it ahhhaa.
fastet H/C N/A 5.3
#26
17,16,15,14,13,12,11 Drvr
man its a pain in the *** doing the heads, spent over 3.5 hours sanding on the block surface to get it cleaned, same as yesterday for the driverside,
you will see when the time comes lance.
#28
I don't know if it's because of it, but I sure regret in doin' the millin on mine............
Months ago I had posted here about my second broken timing chain and bent valves, and I decided to do that while the heads were out.........:30' mill and mild pocket port.
Before this my trap speeds at hot weather were easily 106.highs, the highest that I had trapped was 106.998...almost 107.
Now, I'm barely trapping at 106's. My best so far has been a 106.058 and the other times have been 105.xx, including some 104's
.............in cold weather so I am kind of dissappointed in that. Maybe you guys will think I'm wrong cuz logically it should help, but that's all I have done diffrent to her and well.......I sure regret in doing it.
It's not that I wanna break your bubble, Kev, but it's just something to think about.
#30
Tell that to my truck...............
Also I forgot to mention.....the trap speeds from before were done with stock exhaust pipe, a single in-single out borla, and shorty headman headers.
Now it has Pacesetter Long Tubes with whole 3 inch exhaust pipe.
I never wanted long-tubes for the room it takes when working on the tranny but I had to put em cuz of the pocket port, the shorty's exhaust tube were smaller than the port and the long-tubes were the perfect hole to hole fit.
Two things I noticed right away with heads milled: Trapped less mph and Highway 10mpg!
