Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Troubles... Do they ever end???
Old Nov 2, 2008 | 08:28 PM
DixieDevil's Avatar
Default Troubles... Do they ever end???
Well, went to take the truck to the track today... right before I get there the truck starts actin up. Falling on its face when I hit the gas. I know it was running really lean still. My afr at 5K is 15.3... I am getting it retuned tomorrow. Plus learning more about HP Tuners. It ended put putting its way back home before it died but barely. I think I probably washed out the cylinders again or came close anyways... Oh well, guess I should have gotten it retuned earlier...
Old Nov 2, 2008 | 08:50 PM
DixieDevil's Avatar
Also, has anyone had problems with the Walboro p255 swap? Anytime below 1/4 tank my truck chugs and acts like its out of gas? Is it something to do with the tune or with the install???
Old Nov 2, 2008 | 09:10 PM
terravast4's Avatar
My tuner advised me not to go below 1/4 tank. When that gas get's sloshing around you can run lean
Old Nov 2, 2008 | 09:13 PM
DixieDevil's Avatar
It runs that lean all the time... I need to adjust my MAF. Tomorrow I'm getting another bung put in my header for the wideband sensor so I can start tuning it better. I had it dyno'd the other day thats how I knew it runs so lean... pitiful numbers... 286/310
RandomHero's Avatar
I've read that the pump can't pick up gas from the tank under 1/4 of a tank. It's just the design flaw of the walbro 255.
Old Nov 2, 2008 | 09:15 PM
DixieDevil's Avatar
thanks mark, thats what I was wondering... Anything I can do to remedy this or just live with it???
Old Nov 2, 2008 | 09:22 PM
EDawg's Avatar
mine has a dual 255's and it doesn't do it. but i can't tell you why it doesn't. futral installed it. but its nice to know it can be done
Old Nov 2, 2008 | 09:23 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
There's cavitation and heat. The intank fuel pump uses the gas in the tank as a coolant.
Old Nov 3, 2008 | 06:33 AM
DixieDevil's Avatar
thanks trever, guess I'll just live with it. One day I''ll get this thing straight
Old Nov 3, 2008 | 08:13 AM
dlt76028's Avatar
my walbro did that to. i would hit the gas and it would start sputtering, got annoying real fast so i put a stock unit in there and it works perfect. threw the walbro junk away
