these make a good threesome
Nice! I like my cam so far. Idle sounds stock. It is a Cam Motion custom grind. 223/219 .575 .524 114lsa. You have to get something different from mine though. Just because
Na, I don't give a
what you get.
Are you boring it to a 3.898" or did you ever decide?
Na, I don't give a
what you get.Are you boring it to a 3.898" or did you ever decide?
10 Second Truck Club
Na, I don't give a
what you get.
Na, I don't give a
I do want a reverse split...my blower cam does a good job can't wait to see the difference.I will probly go ahead and bore it... go the whole route while it's apart
With the new heads, intake, cam, and more cubes I don't think i'll have much of a shot at you. Your turbo system hot pipes are much more efficient than mine and not to mention that 80mm turbo
It is going to be scarry when you turn it up. I predict 750rwhp at least when it is all said and done.
Where does the MAP sensor go then? What do you do with the canister deal that goes behind the tb on the factory setup?
Three6GMC
Aug 3, 2015 07:53 PM
