Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
these make a good threesome
Old Jul 8, 2006 | 02:29 PM
CurtD's Avatar
10 Second Truck Club
Default these make a good threesome
MTI stage 2 R heads and Victor Jr...Have not decided on the cam yet any suggestions...GT 42 Turbo will be blowing thru these
Old Jul 8, 2006 | 02:34 PM
TurboGibbs's Avatar
Nice! I like my cam so far. Idle sounds stock. It is a Cam Motion custom grind. 223/219 .575 .524 114lsa. You have to get something different from mine though. Just because
Na, I don't give a what you get.
Are you boring it to a 3.898" or did you ever decide?
Old Jul 8, 2006 | 03:37 PM
CurtD's Avatar
I wouldn't get the same one ...maybe close though I do want a reverse split...my blower cam does a good job can't wait to see the difference.
I will probly go ahead and bore it... go the whole route while it's apart
Old Jul 8, 2006 | 03:41 PM
TexCrew's Avatar
surely
Old Jul 8, 2006 | 03:45 PM
TurboGibbs's Avatar
With the new heads, intake, cam, and more cubes I don't think i'll have much of a shot at you. Your turbo system hot pipes are much more efficient than mine and not to mention that 80mm turbo
It is going to be scarry when you turn it up. I predict 750rwhp at least when it is all said and done.
Old Jul 8, 2006 | 05:25 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That back bung is for the MAP sensor correct? Looks like some fun
Old Jul 8, 2006 | 05:43 PM
TurboGibbs's Avatar
Brake booster most likely
Old Jul 8, 2006 | 06:59 PM
1slow01Z71's Avatar
Where does the MAP sensor go then? What do you do with the canister deal that goes behind the tb on the factory setup?
Old Jul 8, 2006 | 08:14 PM
CurtD's Avatar
Haven't even begun to figure those things yet..i've got plenty of time.
Old Jul 8, 2006 | 11:15 PM
TurboGibbs's Avatar
MAP can pull off any full manifold vacume fitting, TB or intake, whatever. The canister you are talking about is the evap module. He will have to delete that unless he wants to go through the pains to make it fit in the intake somewhere. AL doesn't have emissions testing so who cares.
Oobray
Jun 13, 2022 03:38 AM
Gadgetized
Aug 21, 2020 03:14 PM
Three6GMC
Aug 3, 2015 07:53 PM
elpyro89
Jul 28, 2015 05:51 PM
ALynch
Jul 6, 2015 09:49 AM
