Oil Pump, Double Row Timing Chain
I didn't get anything in today,so i don't know if the timing set has any shims.If it diesn't come wth shims will washers & longer bolts work. I've seen the shims in some sets
No, the shims have passages in them for the oil. You can't just space them with washers cause there will be a gap between the oil pump and engine block where the oil flows through.
Ferocity02
Jul 17, 2015 07:05 PM
