Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
may have a problem.
Old Apr 8, 2007 | 09:12 PM
PappyDan's Avatar
Tribe Shaman
Default may have a problem.
slung my belt.
truck got way over heated.
service light is on.
boiled most of the water out.
what is the chance i killed my motor?
before you ask the temp gauge was peged at 260+.
Old Apr 8, 2007 | 09:15 PM
Derek @ EDO's Avatar
FormerVendor
ahhh, that guage isnt too accurate but i bet the temps were high!
have any idea what the code is?
Did it die?
Old Apr 8, 2007 | 09:16 PM
blake2kz71's Avatar
id be more worried about the alum heads
Old Apr 8, 2007 | 09:22 PM
truckmann's Avatar
might have warped the heads if they got too hot.
Old Apr 8, 2007 | 09:40 PM
tarinitup's Avatar
9 Second Truck Club
that happend to me once and motor worked and performed fine with just a new belt.
Old Apr 8, 2007 | 09:54 PM
Lurius's Avatar
Check the tensioner, that could have been why the belt slung. I know they go out on fbodies sometimes.
-Lurius
Old Apr 8, 2007 | 09:55 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt be worried at all, Pappy. I didnt overheat my truck like but the story goes something like this:
Went down to the beach me, and a girl slept in the backseat of my truck, I kept remote starting it with my alarm to get some ac going, it automatically turned off after 15 minutes so I said screw it and started it up with the key and left it running. Woke up about 10am with hot air blowing on me and the temp gauge pegged at 260 and the trans temp gauge pegged at whatever, who knows how long it was like that, because it was in the middle of summer on the sand with a clutch fan so you do the math on the overheating problem. Nothing was wrong wtih the motor when I pulled it about 30K later, the cylinder were perfect, the heads gaskets were fine. If it isnt consuming any coolant I wouldnt worry about it, I think you wil be fine.
Old Apr 8, 2007 | 09:58 PM
blake2kz71's Avatar
gotta love a good excuse to build something if it did any damage
Old Apr 8, 2007 | 10:20 PM
PappyDan's Avatar
Tribe Shaman
belt went on the way home.
it did not shut down, got the spare belt on and it is running.
no smoke out of the pipes but their is a large amount of tiny bubbles
coming up in the coolant tank now, may have lost a head or gasket.
Old Apr 8, 2007 | 10:29 PM
FormerVendor
go drive it like ya stole it! that will tell ya!
