Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
A little help please
Old Dec 28, 2006 | 06:51 AM
2k5Squirrel's Avatar
14 Second Truck Club
Default A little help please
i am putting the GMC tail lights on my truck. do y'all know if anything has to converted over to make everything work? i know you switch to the newer tail lights you have to do a little modding.
TIA, Jason
Old Dec 28, 2006 | 08:04 AM
BLACKND's Avatar
I know when I changed from the GMC Tails to the Silverado tails, I used the new harness. The silverado has 4 bulbs and the GMC has 3 bulbs, plus I think the shape of the inserts are a tad bit different, but you could most likely make them work, its just that extra bulb sitting out there that will be the issue.
Old Dec 28, 2006 | 09:28 AM
i think i'm getting the harness and everything else with these. hopefully it's just plug and play.
Old Dec 28, 2006 | 09:30 AM
BLACKND's Avatar
If you get the harness, then yes, it should just plug right in and be no issue. I know some have spoke about the taillight itself not fitting properly into the opening, but I have had no issues whatsoever with any of mine on this swap.
