Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
LED lights.
Old Feb 16, 2008 | 09:59 PM
PappyDan's Avatar
Tribe Shaman
Default LED lights.
i have seen pictures of what others have done,
looks damn nice.
so i thought i would give it a try today on the controls
for the ac and heater.
well got it done, wife wants me to do hers now, but.........
have some bad news.
all i did was change out the lights and i have no control over the vents.
the vent is open on the dash and will not move.
i have no control over the ac or heat.
the heat is now on all the time.
i don't know how i did it, but i screwed it up, it looks pretty but it
don't work any more.
now i have to buy a new control unit, just wish i knew how much i screwed
my self for?
Old Feb 16, 2008 | 10:01 PM
jakebdb56's Avatar
I think the control unit sells for 90'ish from the dealer. I remember seeing somewhere on tech where the same thing happened to another member. It was totally screwed.
Old Feb 16, 2008 | 10:10 PM
PappyDan's Avatar
Tribe Shaman
well all i did was change out the little light blubs for super brite leds.
i so wanted to do my cluster but i wont touch it now.
Old Feb 16, 2008 | 11:44 PM
Colby 04's Avatar
did you use a resistor in series with the LED's?
Old Feb 16, 2008 | 11:48 PM
jakebdb56's Avatar
You can do the cluster, Matt (TooTall) has a thread on how he did it. All it is is about 10-20 bux of special little LED thingies that plug right in.
Old Feb 17, 2008 | 12:18 AM
Tootall's Avatar
sounds like you got a resistor too hot . . .
What kind of LEDs did you use in the a/c controls? . . . did you replace the stock resistor
I killed my first one, I used a probe soddering iron, and I messed up something on the board.
Old Feb 17, 2008 | 01:17 AM
silver-mod-o's Avatar
Hunt&Fisherator
There's gotta be a plug and play kit for this stuff to keep from soldering on your controls and stuff...
Old Feb 17, 2008 | 02:46 AM
PappyDan's Avatar
Tribe Shaman
i used the 5mm super brite leds to replace the bulbs.
i used 1 resistor with 1 led on each socket.
replaced the 4 bulbs on the large panel that back lit the controls.
then replaced the 4 smaller bulbs on the small panel that lit the buttons.
i found a replacement control on e bay.
Old Feb 17, 2008 | 07:52 AM
ThunderZ28's Avatar
12 Second Club
wow.. it's that hard????
ON my 99 camaro mine where just plug, and play..( for the ac controls)
I will be working with a guy some to see what we can come up with for the 99-06 trucks...
as far as a kit goes.. maybe we can figure out a better way..
Old Feb 17, 2008 | 11:33 AM
Colby 04's Avatar
I replaced the bulbs in my temperature control unit just before I sold the truck. Those bulbs are soldered in and have no "plug and play" capability. I didn't have any problems, but I'm also in the electronics profession.
