Im screwed!!
Originally Posted by $thatguy$
listen i didn't half *** ****... i missed one little thing while doing his truck... no reason to ****** bad talk me for a small problem. and 07 keep your fuckn mouth shut.
Good thing it wasn't in the main spark adv tables
, that one little thing could have been bad. Dont feel bad I am still learning the ropes as well. Keep your head up and learn from your mistakes. Best of luck to you.
...and you just redeemed yourself
Originally Posted by 1BADC10
HPTuners has a Shift Speed table for mph points the PCM will use to acknowledge an acceptable speed (mph) and engine revolution (rpm) to allow a shift to occur. If those parameters are met, then the shift occurs. RPMs (if not mistaken) is the final "say so". That's obvious b/c if the RPMs are set too low, and the mph point is too high, you'll hit the limit before the mph is reached... thus the vehicle falls on it's face & bouncing the limiter.
As a part of that same table, there are downshift characteristics regarding designated mph points versus throttle position. If your downshift cells are set to "zero" or they're set lower than what you need, then I can understand why you will not get a downshift @ WOT. I hope that is not what was done.
tell 07 to shove it up his butt!!!! Live tunes will be better then mail orders. NO ONE CAN DISAGREE!!!!! Each truck is different and some can except more timing, little different af/r and pe/ve tables. Many different factors. And ive put well over 20 hours with my tuner or close to it and I still wouldnt mind going back to him for another 5 hours on a saturday. It wont/cant be done in one day. People who drive the faster vehicles on here and tech leavet heir laptops hooked up 100% of time and constantly logging.
Keep at thatguy. Just dont catch yourslef on fire agian.
GM1697
Sep 9, 2015 01:52 PM
smokeshow
Aug 23, 2015 08:23 PM
