Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
How do I get a broken, corroded bolt out?
Old Mar 10, 2008 | 01:55 AM
CashDudeHomie's Avatar
I ended up hitting it with a punch to try to loosen it, and the bolt started to break around where the easyout was stuck inside. I was able to remove the easyout with needlenoses, and then I eventually just drilled out the old bolt and tapped the threads. I think I drilled it perfect and was tapping into the original threads because it went in pretty easy. I then cleaned up a bunch of metal shavings from the bottom of the hole and the new bolt (maximum strength) went in perfectly. I had never used a tap before, so I was scared as hell that I was going to screw it up, but it worked. Also I bought some PB Blaster, and it's great. Thanks for the help guys.
Old Mar 10, 2008 | 07:39 PM
pittman's Avatar
Dude, keep soaking that bitch with break free or something. It takes a lot more time than squirt\twist. Soak for a week ...(spray it every day) then vice grip it. And I mean vice grip it..should take two hands and all you got to close the grip and don't pinch your skin...**** hurts...haha.
Pit
Old Mar 11, 2008 | 12:46 PM
Yogi Bear's Avatar
Those situations where the e-z-out breaks off don't usually turn out too good. I'm glad it all worked out well for you! Congrats!
Old Mar 11, 2008 | 05:56 PM
Sticky Bumps's Avatar
Yeah, congrats...always love to hear about success when that **** happens.
Pit from above (couldn't log in tonight)
flatblack83
Jan 3, 2026 07:10 PM
zblee
63
Jun 10, 2023 01:25 PM
JFortner5
Aug 20, 2015 06:13 PM
4B11T
Jul 13, 2015 03:48 PM
MileHighSierra
Jul 12, 2015 12:23 AM
