Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
High speed Road force wheel balance in Baton Rouge, LA?
Old Mar 22, 2014 | 11:49 AM
Darknight-4's Avatar
Question High speed Road force wheel balance in Baton Rouge, LA?
I am looking to get my wheels High speed road force balanced, or at least road force balanced somewhere around the Baton Rouge area.
Does anyone know a shop that does this?
Basically I think I'm down to it being tires or rims causing a vibration issue after correcting pinion angle and replacing driveshaft with 5" aluminum high speed balanced.
They are balance through the normal method, but I have been told that at higher speeds and/or road force it can change balance dramatically and I'm wanting to fix this.
Thanks
Old Mar 24, 2014 | 11:40 PM
SwampBowTie's Avatar
Registered User
No shops im aware of, try reaching out to that custom truck shop up there. I forget there name. Bigger shop, usually does shows at twin peaks. I'm from no and spend a few weeks a year up there for work. Good luck in the search..
slowlsx
Aug 13, 2015 08:28 PM
ullose272
Jul 19, 2015 04:14 PM
dvtech
Jul 6, 2015 03:02 PM
