Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
help in houston area.
Old Apr 28, 2006 | 12:03 PM
  #31
FarmerBeau's Avatar
Sexy Party Mod
I tried getting mine in from the top but im pretty sure that envolved messing with the steering.....yea ***** that and jack it up a few ft!!!
Old Apr 28, 2006 | 12:04 PM
  #32
white1's Avatar
If you only knew
Old Apr 28, 2006 | 03:08 PM
  #33
FarmerBeau's Avatar
Sexy Party Mod
Originally Posted by white1
If you only knew
Do tell.
Old Apr 28, 2006 | 03:45 PM
  #34
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I can tell you how. May not be the same way others do it, but it has worked for me several times. Pull the old pulley (I assume you can do this) Use a torch and heat the inside of the new pulley and slide it on, it should go all the way without having to "pull" it on with a bolt. It is recomended to use a new bolt, but I have only once. If you re-use the old bolt Id slap a little lock-tite on it while you have it out. I think the torque specs are 80 lb-ft then 140* but I just tighten the **** out of em.
Old Apr 28, 2006 | 10:29 PM
  #35
white1's Avatar
Originally Posted by FarmerBeau
Do tell.
It was my turn to post, and you cut. I am jealous he has access to a lift and I dont.
BTW you dont have to touch the stearing to change the pulley. Whyd you think that?
Old Apr 29, 2006 | 11:58 PM
  #36
FarmerBeau's Avatar
Sexy Party Mod
Very sorry about the whole cutting thing
I thought that because we tried to get them in from the top and it didnt work too well cuz the damn steering crap was in the way.
LSXstef
Jul 19, 2016 02:59 PM
Ws6ickness
Feb 5, 2016 02:42 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
GMCtrk
Oct 20, 2015 06:17 AM
lxcoupe
Oct 4, 2015 08:07 PM
