Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
A few changes (pics)
Old Jan 19, 2008 | 03:30 PM
CurtD's Avatar
10 Second Truck Club
Default A few changes (pics)
Put a line lock on the truck, moved my gauges from the A pillar and consolidated all of the switches. I like it alot better...just have to get used to looking to the right instead of the left.
boost/afr/egt
line lock/two step/two stage boost control/ the red light is on when the line lock is activated ,so maybe i won't go down the track with just the front brakes
I tried the line lock, it's going to make for a good burnout at the track.
Old Jan 19, 2008 | 03:52 PM
explorer5.0's Avatar
TOTM: November '07
ok, I am confused- it looks like the lock is on your rear brakes.. Are you locking the rears so they wont see pressure when you hit the pedal? I normally think of a line lock holding the front brakes on.
Old Jan 19, 2008 | 04:11 PM
Klive's Avatar
Banned
yea, a line lock on the rear brakes is all wrong...
Old Jan 19, 2008 | 04:16 PM
CurtD's Avatar
Yea, it"s on the rear because of the anti-loc brakes. And you install it opposite of what the directions say as far as the line connections.
When you want to use it,
Flip the switch before you apply the brakes (then no pressure can go to the rears)
Apply the brakes
Do your burnout
Flip the switch off
Good to go.
Old Jan 19, 2008 | 05:15 PM
Klive's Avatar
Banned
why not just install it like it is designed to be used and put it on the front brakes? i mean, you're the only individual i've ever seen do what you're doing. however, if you like it...go for it.
Old Jan 19, 2008 | 05:50 PM
TOTM: November '07
Apply the brakes
Do your burnout
Flip the switch off
Good to go.
I guess blocking the rears would be cool for burnouts, because you can control the forward roll out of the water box with the front brakes.
Old Jan 19, 2008 | 06:00 PM
00Silv4.8's Avatar
it makes more sense to reverse it for ABS cuz then if u wanna do some sweep 600ft rubber down ur street or somethin u just flip on the line lock and keep it rollin. Saves rear pads and all in the long run. Looks dam good tho, I been thinkin about guages for when I put it on the bottle and I like using the overhead stowage so thats a bad *** place for the gauges
edit: and hes the second one to do it thats on this site (who has posted). Theres a guy with a Dmax that did it
Old Jan 19, 2008 | 06:17 PM
CurtD's Avatar
Thanks ,must be because you haven't been around much...that's how it's done on these trucks.
Old Jan 19, 2008 | 06:23 PM
Klive's Avatar
Banned
actually i've been around MUCH longer than you, just never posted on the truck site before. thats not how its done on these trucks, its how you did it on your truck. most of us with line locks have them done right.
Old Jan 19, 2008 | 06:29 PM
00Silv4.8's Avatar
how the hell is there a right and wrong way? I personally think the reverse loc is a better idea so u have control over ur movement so u could correct if ur *** end starts goin side ways u can turn and let off the brake a bit. Just makes more sense so ur not stationary
