Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Booommmmm!!!!!
Old Sep 9, 2006 | 09:49 AM
  #41
v8
17,16,15,14,13,12,11 Drvr
if you look at flt and century its the same trans, I have no problems with century trans at all, I don't even know if its was there trans of the converter yet, if could of been the pump that went out, now 02denali had a problem with them but I do believe it was equal between the two.
  #42
v8
Originally Posted by LS1Silverado98
Hey just out of curiosity, what do you have done to your rear suspension for traction?
stock suspension.
Old Sep 9, 2006 | 10:04 AM
  #43
v8
Finish line trans stage 5
FLT performance pump
Cryogenically treated FLT sleeved input drum
Cryogenically treated input sprag races
Cryogenically treated low roller race
Cryogenically treated bearing style reaction shaft
Cryogenically treated output shaft
GM 5 pinion planets front and rear
Wide 2-4 band
8 B/W high-energy clutches in 3-4 pack
FLT beast shell w/bearing
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Bushing kit
All solenoids
Internal wire harness
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated accumulator pistons
Set end play to performance specs
Deep GM pan (n/a C-5 corvette model)
Sonnax super hold 4th gear servo
century trans.
*Transgo 4L60E-HD2 Shift Kit (including internal modifacations)
*HP 3rd clutch piston Return Spring Kit
*13 vane pump kit, clearanced to spec.
*Hardened Pump Support Rings
*HP Pump Slide Spring
*Alum. Accumulator Piston Kit (replaces plastic ones that tend to crack)
*Century HP Wide Band (3/8" wider than OEM w/Kevlar linning & reinforced strut ends)
*Billet Super 4th Servo (firmer 4th apply & longer band life)
*Century HP 3-4 Clutch Kit: Special Alto Red Eagle Racing frictions, Koleen steels, pressure plate & snap ring. Increases clutch count from factory weak 6 to awesome capacity holding 9! A must for any HD/Performance 4L60!
*Century HP Sun Shell Kit: Hardened steel sleeve is furnace brazed on to reinforce splined area of sunshell (another weak link). Includes modified sprag race & rollerized thrust bearing to replace cheesy plastic thrust washer. Over 300 sold w/no failures!
*New 29 Element H.D. Input Sprag
*5 Pinion Rear Planetary Gear (25% stronger than 4 pinion gear) This a NEW G.M. component which is more expensive than the inferior, unreliable foreign made units
*2-3 Check Valve Kit: improves timing between band servo release & 3rd gear apply
*Reverse Capsule Update: decreases bleed oriface size in piston for better reverse engagement
*All clearances & end-play set to our performance specs
*Hardend Input Drum w/reinforced alloy sleeve
*Hardened Input Shaft
*Input Drum & Shaft balanced at 9500 rpm!
*New forward piston
Old Sep 9, 2006 | 10:15 AM
  #44
ap2002's Avatar
not that century is bad but I have heard mixed comments about them.... and FLT has gotten real good reviews and havent heard of one busting yet...
Old Sep 9, 2006 | 10:25 AM
  #45
kevin, your cent. trans did you do any of the upgrades available on the stage II?
Old Sep 9, 2006 | 10:27 AM
  #46
v8
like I said wont know untill monday what went wrong or broke, remember this trans is 1 year old with about 250 track passess and 30k mileage since it was installed.
Old Sep 9, 2006 | 10:28 AM
  #47
v8
I went back and looked at my paper work and I only had a stage 1 trans.
  #48
bluecajun5.3's Avatar
11 Second Truck Club
damn kevin, sorry to hear about the tranny issues.
hope you get it all worked out.
i guess i'll be next
Old Sep 9, 2006 | 10:30 AM
  #49
thats quite a beating, im glad to hear one of their tran held up that well, what HP is their stuff supposed to be able to push? ill be looking forward on monday to hearing if it was the trans or the converter
Old Sep 9, 2006 | 10:34 AM
  #50
v8
the stage 1 is supposed to hold up to 450 rwhp and stage 2 700+ rwhp
