Booommmmm!!!!!
#41
17,16,15,14,13,12,11 Drvr
if you look at flt and century its the same trans, I have no problems with century trans at all, I don't even know if its was there trans of the converter yet, if could of been the pump that went out, now 02denali had a problem with them but I do believe it was equal between the two.
#43
Finish line trans stage 5
FLT performance pump
Cryogenically treated FLT sleeved input drum
Cryogenically treated input sprag races
Cryogenically treated low roller race
Cryogenically treated bearing style reaction shaft
Cryogenically treated output shaft
GM 5 pinion planets front and rear
Wide 2-4 band
8 B/W high-energy clutches in 3-4 pack
FLT beast shell w/bearing
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Bushing kit
All solenoids
Internal wire harness
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated accumulator pistons
Set end play to performance specs
Deep GM pan (n/a C-5 corvette model)
Sonnax super hold 4th gear servo
century trans.
*Transgo 4L60E-HD2 Shift Kit (including internal modifacations)
*HP 3rd clutch piston Return Spring Kit
*13 vane pump kit, clearanced to spec.
*Hardened Pump Support Rings
*HP Pump Slide Spring
*Alum. Accumulator Piston Kit (replaces plastic ones that tend to crack)
*Century HP Wide Band (3/8" wider than OEM w/Kevlar linning & reinforced strut ends)
*Billet Super 4th Servo (firmer 4th apply & longer band life)
*Century HP 3-4 Clutch Kit: Special Alto Red Eagle Racing frictions, Koleen steels, pressure plate & snap ring. Increases clutch count from factory weak 6 to awesome capacity holding 9! A must for any HD/Performance 4L60!
*Century HP Sun Shell Kit: Hardened steel sleeve is furnace brazed on to reinforce splined area of sunshell (another weak link). Includes modified sprag race & rollerized thrust bearing to replace cheesy plastic thrust washer. Over 300 sold w/no failures!
*New 29 Element H.D. Input Sprag
*5 Pinion Rear Planetary Gear (25% stronger than 4 pinion gear) This a NEW G.M. component which is more expensive than the inferior, unreliable foreign made units
*2-3 Check Valve Kit: improves timing between band servo release & 3rd gear apply
*Reverse Capsule Update: decreases bleed oriface size in piston for better reverse engagement
*All clearances & end-play set to our performance specs
*Hardend Input Drum w/reinforced alloy sleeve
*Hardened Input Shaft
*Input Drum & Shaft balanced at 9500 rpm!
*New forward piston
Wide 2-4 band
Corvette Servo
Bushing kit
All solenoids
Spacer plate
B/W clutches
Seal & gasket kit
Filter
century trans.
*New forward piston
#47
Originally Posted by Soon2bSpooled
kevin, your cent. trans did you do any of the upgrades available on the stage II?
#49
Originally Posted by v8
like I said wont know untill monday what went wrong or broke, remember this trans is 1 year old with about 250 track passess and 30k mileage since it was installed.
