Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
anybody got an OBS truck.. need an answer
Old Jul 20, 2006 | 09:39 AM
ThunderZ28's Avatar
12 Second Club
Default anybody got an OBS truck.. need an answer
Got a 99 Yukon..
recently I have noticed that the truck has been having a musty smell to the interior..
so opon further inspection I have found that the where the 2 condensor lines go thru the wall, as well as the drain hose for the A/C, it is leaking really bad here where there is a foam seal around all three lines..
the leak is between the firewall and the foam seal..
what can be done here to fix the problem????
anybody have this problem before?
I havnt had to mess with one yet, although I here it is a common problem..
thanks for the help,
Daniel
Old Jul 20, 2006 | 10:14 AM
Nick™'s Avatar
is it just a condensation? if so fill up the hole with some rtv or something... then insulate the tubing just like you would a residential a/c, electrical tape or some pipe insulation will do
Old Jul 20, 2006 | 05:01 PM
heavychevy454ss's Avatar
Is it the condensate overflowing? Your drain line could be pluged. Fairly common. If the seal is bad, not sure if you can get a replacement.
Old Jul 20, 2006 | 05:44 PM
ThunderZ28's Avatar
12 Second Club
I shoved a coat hanger up into the drain, it still is coming inside...
dont know what else I can do.
Old Jul 20, 2006 | 07:03 PM
Nick™'s Avatar
is it where it's going through the firewall? can you maybe spray some expanding foam up there to surround the pipe? basically if you can insulate the pipe it won't sweat and the problem is solved. If it's the actual coil that is sweating that much, other than cleaning the drain hole, there really is nothing you can do.
Old Jul 20, 2006 | 10:38 PM
ThunderZ28's Avatar
12 Second Club
Humm, I have some great stuff, I may try that and see what it does..
sTNT971
Sep 26, 2015 06:27 AM
Tuckin15s
Sep 23, 2015 09:35 PM
lxcoupe
Sep 23, 2015 12:11 AM
lxcoupe
Sep 21, 2015 11:53 AM
zblee
Sep 17, 2015 07:58 AM
