Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
After 8 months it's finally a driver
Old Feb 17, 2007 | 04:40 PM
CurtD's Avatar
10 Second Truck Club
Default After 8 months it's finally a driver
Last April i bought Creederado's 99 rcsb truck and decided to kick it up a notch. In June we took the engine out and swapped it into my 01 ext cab truck and sold it. Sent the engine from the ext. cab ( that was turbo charged) to the machine shop had them make a little stronger (hopefully) . Then figured i needed a stronger trans, so FLT hooked me up with a PI 3200 converter and an 80e level 4. Then called up Denny's for a good driveshaft with 1350 u joints and a forged pinion yoke. The rear end already had an eaton locker and 410 gears, but 342's would load the turbo and help with spool up so i had them installed. Put some 555r's on the rear and changed out the front rims from 9.5 to 8" to get them inside the fender wells a little. I have thank Chad@ Greenlight Motor sports with the EXCELENT help getting me going in the right direction with EFILIVE speed densiity auto tuning . If your looking for some tuning software give him a call he will help you with your decision
Some specs on the engine;
5.3 bored 30 and balanced, Eagle rods, ross pistons, morgan motorsports heads, jesel valve train, comp 220/216 cam, vic jr. intake,and an elbow from intake elbows.com
4" from front to the back
Old Feb 17, 2007 | 04:45 PM
v8
17,16,15,14,13,12,11 Drvr
That looks great and very good work from past to present. Now its time for some track times.
Old Feb 17, 2007 | 04:47 PM
JJ_TURBO's Avatar
11 Second Truck Club
Super nice truck and setup, good luck with it, now go get some good numbers.
Old Feb 17, 2007 | 04:57 PM
Colby 04's Avatar
That truck is sexy
Old Feb 17, 2007 | 05:11 PM
jgun's Avatar
Looks Like Somebody Spent A Few Dollars. Looks Killa
Old Feb 17, 2007 | 05:28 PM
ZR1 DREAMING's Avatar
Very sharp! Got any close ups and details of your vic jr and fueling set-up?
Old Feb 17, 2007 | 05:40 PM
CurtD's Avatar
Thanks everyone, its been a long bumpy road...but well worth it .
I can get some pics of the intake. I have dual intank walbros, secondary pump is on a hobs switch set at~ 6# .using the rails that came with the intake ( got it from WCCH) -6 feed lines running to each rail with an aeromotive adjustable FPR and 72# @ 58 psi injectors from livernios.
Old Feb 17, 2007 | 05:54 PM
Sounds nice. You have done a very nice job on the truck! That engine bay is *****!
Look forward to the pics
Old Feb 17, 2007 | 05:55 PM
CurtD's Avatar
Old Feb 17, 2007 | 06:00 PM
speedy02's Avatar
Looks fast!
