Wats ur MPG???
#42
guys got any info on why my 2004 6.0 2500hd manual 5 speed is only gettin 10.3 with 285's and 4.10's? custom 87 tune, replaced stock muffler with bullets, cold air intake.
i was pretty pissed to see my numbers!!!!! that was calculated on half a tank of 11.5 gallons and 117.5 miles!!!!!!!!!! any way to set a/f tables for cruise mode on a manual?
#43
best way to measure gas if getting the recipt of how many gallons you put in and divide by actual miles
#44
i did just that, topped my tank off all the way. then set the trip. after it was a bout half way down i figured it was enough gallons gone to measure a good bit. so i topped it back off by putting 11.5 gallons back in it, then divided by the 117.5 miles i put on the half tank (well what read half tank). thats 10.2 mpg. now 285's are not a huge tire and mine are not overly wide, the 4.10's should have no problem turning them over. i am not trying to compare my truck to a 5.3 or half ton. i know my truck has heavier everything and more displacement. just doesnt match up to most other hd's. i guess well have to play with it quik? higher octane-better mileage?!?!?
#46
fully bolt on I got 450-490 to a full tank....fully bolt on/stall I got 360-370 miles to a full tank....fully bolt on stall/cam 290-320miles to a full tank....and now that I'm just fully bolt on and cam i'm getting 380miles to a full tank, about 14.6 mpg.
#48
i read trip (-odometer) and thought you were talking about a trip you took lolya that is pretty bad, ive heard of guys wit 6.0s wit basically little or no mods getting around 13-14 but your really low
gaps
Oct 15, 2015 02:53 PM
