Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Switching to OEM brakes
Old Jun 8, 2010 | 04:57 PM
  #31
jadaven's Avatar
Yeah, In the name of cost when it's time to replace these I'll be going back to the stock set up. Still have some D/S rotors for looks.
Old Jun 23, 2010 | 10:21 PM
  #32
11 Second Club
i turned my rears on a brake lathe at work... just went really really slow.... turned out just fine...
Old Sep 9, 2010 | 02:50 PM
  #33
Terry Hesticles's Avatar
Correct me if I'm wrong, but I was under the impression that the brake pads and rotors from a 2500 HD fit perfectly with the RST setup. Is it just the pads? Is it neither?
Old Sep 10, 2010 | 05:40 AM
  #34
RED04REGENCYRST's Avatar
regency didnt replace the factory 1500 caliper, just the rotor with a relocation bracket. so after replacing the caliper brackets with stock one and the rotors i was back to stock brakes.
Old Sep 13, 2010 | 12:08 PM
  #35
So what about the rotors? It was here that I believe I saw people mention using 2500 HD rotors.
I need to change out my brakes, but want to keep the same size.
Old Sep 14, 2010 | 05:49 AM
  #36
i believe if the 2500 rotors are close to the size of the after market rotors, but im not 100%. i do know the 2500 rotos are thicker than the 1500 rotors and youll have to change out calipers to the 2500 calipers.
Old Sep 14, 2010 | 07:58 AM
  #37
So I should just bite the bullet and order the Baer rotors, eh?
Old Sep 14, 2010 | 08:38 AM
  #38
you could search for the 14" powerslot rotors and have them cryo treated.
i just couldnt swallow the $400+ it was gonna cost to replace the fronts.
start here:
https://www.performancetrucks.net/fo...rvette+caliper
Old Sep 14, 2010 | 09:13 AM
  #39
start here:
I looked through your photobucket yesterday. I did it at work so I couldn't invest a lot of time into everything I was looking at, but notice you have the 6.0.
It sounds really, really good. Besides the tranny, I didn't catch what all was done to it (CarDomain.com is blocked at work, too). What all have you done to the swapped out power plant?
Edit: And thanks for the link!
Old Sep 14, 2010 | 12:12 PM
  #40
the motor is a stock lq4, aside from a thunder racing 220/220 .551/.551 112lsa cam, valve springs, hardened push rods, tbss intake w/ 42lb injectors, dr.x harness for the 90mm tb.
you wanna see vids you should click the link in my sig and go to my youtube page.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Velocity1
Sep 15, 2015 11:29 PM
Noah Burns
Sep 13, 2015 09:28 AM
Alco
Sep 4, 2015 04:08 PM
jtphelps289
Sep 1, 2015 08:58 PM
