SilveradoSS Modifications
#31
Year/ your truck / audio / cosmetics:
2003 Arrival Blue SSS
Stock Bose Audio System
Bell Tech 2/2 Lowering kit W/ Energy Suspension Bushing Kit and Links
engine size: (stock, cubic inches, liters, etc.)
LS3 376 ci. 6.2L Aluminum Block W/ 24x reluctor converson
ARP rod and head Bolts
camshaft: (stock or xxxx lift, duration, brand)
Comp Cam 224/230 Dur. .581 in. / .591 ex @ 114 LSA
cylinder heads: (stock or xxxx brand or hand ported/also valve train choices)
LPE Stage 3 ported Comp Cam Springs 921 w/ locks and retainers, Polished rocker arms w/ trunion kit installed and Comp Cam 7.4 pushrods
pullies: (stock or other)
Stock
intake system: (stock intake, blower (type, boost level, etc...), cold air intake, etc.)
L92 intake with TBSS 33lbs injectors and K&N cold air with coustom inlet pipe
exhaust system: (from manifolds headers all the way back)
OBX headers and Borla Single 3"
pcm modification: (stock, edit, hp tuners, custom tuned, etc. )
HP Tuners by ME mostly
spark: (wires, plugs, gap, etc.)
NGK TR6 MSD 8.8 wires
Drivetrain:
RPM Transmissions Level 7, Micropolished 4:10 ring gears ft and rear, Micropolished Transfer case, Detroit True Trax with studded caps and Reienforced aluminam diff cover
Other:
NOS plate nitrous system 200 shot, NOS activation system
NOS purge system, NOS bottle heater, LPE timming / studder box, Innovate wideband, and Dual pod pillar with A/R and nitrous gague
Stock
Drivetrain:
Other:
#32
Looks like from the dust it has been a while since anyone was here.
2003 black SS Silverado, 48,000 miles
Black billett grille, smoked headlight, running light and tail light covers.
Volant cold air induction
Ported throttle body
1:8 to 1:00 ratio Comp Cams full roller rockers w/behive valve springs, .100 wall thickness 3/8" pushrods.
BBK headers, Dougs Headers remote controll cutouts, Flowmaster exhaust.
HP tuneup
Used for landspeed racing in production pickup class with the ECTA.
Top one mile standing start had a constant quartering cross wind hitting in the drivers door and left front fender ran best of 133.869 in 5830 lb. truck.
HP tuneup
