Resurrecting a Gibbs
#81
#82
The effort for the 80e will be worth it. If I could do it all over again it would be 80e. Learning along with the builders on the 6l80 was not fun or cheap. I’ve never heard of a 4l60 living behind a supercharged setup for long, the instant boost kills them, at least from my friends expirence.
#85
Well, figured I would bring this back to life. Truck has sat on jackstands for the last year. I am going to go the 4L80e trans route. Deciding if I want to tackle it myself or just put it on a trailer and take it to a shop to be done. The hotrod power tour is coming through town this year, so I kinda have that as my goal to get the truck back on the road.
#89
I can only try and imagine trying to drive that build. I put 400HP to the ground via 8psi in the weight of a 1500 ECSB 4x4 and stock tire size with 3.42 gears and hardly posses the skill to keep from roasting in an aggressive launch.
I guess I would talk to your engine builder what it would be like to run each those gears in your setup. Can't wait to see. If you don't have a name for her perhaps let it be RIOT!
#90
If you want the most out of an inter-cooler heat exchanger see https://mercracing.net. He used to be a member here and still may be but didn't get lots of flow in the big 3 market and the imports found him, but if you want custom over off the shelf check him out.
