Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Regency RST Complete Write-Up Info
Old Aug 27, 2012 | 02:27 PM
  #2321
RED04REGENCYRST's Avatar
Originally Posted by Silver05Rst
Just when i think im finally done dealing with this stupid tranny yet another problem has come up..... Well i finally got it working with SO much help and advice from Billy, so an UBER thanks to ya man firstly!!! Now onto the bad news... Finally got it up to the strip today. Still have alot of parts to put on it, but on my engine setup and the 4.88's with the 6-speed i managed to do a new personal best with track conditions horrible and still spining the first 60ft... 15.28 @ 91.82 mph, anywho thats not the problem. The problem occured on the drive back home. My clutch is defintly slipping. 6th gear is TERRIBLE, you put the gas pedal down and it just revs up slowly but your not accelerating... Im thinking its got to do with the pedal because theres 0 freeplay in it and it engages/disegauges like as soon as u push the pedal down. I gotta adjust it someone how. A buddy of mine says theres a pin at the end of the clutch (i think) that u take out and screw in or out to adjust freeplay in your pedal. Thoughts?
I've never heard of anything being adjustable on a clutch itself. I'm trying to think what would cause that. I wonder if they put the aftermarket shim in behind the oem slave you finally got them to put in. If they did that, your pressure plate is never fully engaged. That would cause you to slip, but I would think it would happen in a lower gear.
Old Sep 14, 2012 | 12:58 AM
  #2322
kren7604's Avatar
Billy, where did you get your 4.88's?! I'm lookin into buying gears and a TrueTrac so I can get off the line with more get up an go
Old Sep 14, 2012 | 01:01 AM
  #2323
I don't remember where I bought them, but they are yukon gears.
Old Sep 17, 2012 | 09:43 PM
  #2324
kren7604's Avatar
Alrigtht so heres my next mods:
1. Detroit TruTrac locker and 4.88's (within the next month or so)
2. LT's and offroad Y-pipe to duals w/ no cats, 2magnaflow mufflers to tips off the bumper
3. Intercooled Supercharger or procharger, still looking into options/ hp gains vs price
4. Spray!! havent decided but I might do spray before Boost. my motor is built for spray as it is and its alot cheaper lol
Old Sep 22, 2012 | 04:27 PM
  #2325
Well that was a long read for sure but it definitely made up my mind I'm gonna buy one of these come tax time
Old Sep 22, 2012 | 11:05 PM
  #2326
5speedsilverado's Avatar
any one know how to get the throw out bearing off the slave cylinder?
Old Sep 22, 2012 | 11:23 PM
  #2327
Just grab the bearing and pull. You might get the whole to half if the slave first, but the bearing will come off with a little elbow grease.
Old Sep 22, 2012 | 11:52 PM
  #2328
its that simple? lol thanks!
Old Nov 13, 2012 | 09:16 PM
  #2329
RSTinOKC's Avatar
Kren, nitrous and turbo/sc builds "should" be very different. You can run alot more CR on nitrous than you can on the other good luck man and have fun
Old Jan 11, 2013 | 07:28 PM
  #2330
RSTinOKC's Avatar
Past couple of days I've been noticing an intermittent mushy clutch pedal. Tonight after stopping to pick up a 12 pack I get in the truck and the clutch goes to the floor. I checked the fluid and it was low so its obviously leaking somewhere...ran in the store grabbed some fluid and pumped the **** out of the clutch and it got me home. I haven't looked for leaks yet but does this sound like the slave or the master?
