Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Regency RST Complete Write-Up Info
Old Feb 26, 2012 | 05:06 PM
  #2001
RSTinOKC's Avatar
Made my first run down a track today but only had time for one run: 18.314 @ 93.48...3.31 60' spinning and bouncing the whole way
Old Feb 26, 2012 | 05:08 PM
  #2002
RED04REGENCYRST's Avatar
Sounds like a really cold track. Were you on street tires?
Old Feb 26, 2012 | 09:45 PM
  #2003
kren7604's Avatar
Hey guys im new here, I have an 04 Regency RST black with red stripes. Im getting ready to do a ls6 and t-56 swap, my motor is out of 202 z06 405hp plus I installed a comp cam 224/230 113lsa .581/.588 lift cam and 918 behive springs. Here in about a month im gona have a Keisler front shift conversion installed into my t-56. once that gets done im gona start my swap
Old Feb 26, 2012 | 09:57 PM
  #2004
i dont know much about the shifter conversion, but i dont think it will move the location forward far enough to work without modification. you might want to check on the measurements, cuz when i installed mine it didnt look like it would line up.
by the way, sounds like a nice setup, good luck with the build.
Old Feb 26, 2012 | 10:09 PM
  #2005
kren7604's Avatar
thanks, from what iv read so far its only about 1.5 - 1.75 inches back from where my stock 5 spd is, it uses the secondary port on the t-56.. id like to keep my jumpseat and any bit i can get it forward helps lol
Old Feb 26, 2012 | 10:17 PM
  #2006
the only question that comes to mind is, what are you going to use for a boot around the shifter if you widen the hole?
Old Feb 26, 2012 | 10:35 PM
  #2007
kren7604's Avatar
I was just gona slide it back to the needed position and then add black carpet to the front where the floorboard would be showing.. heres a link to the front shift conversion im thinking about T56 Front Shift Conversion Kit | Shifters, Handles & Boots | GM Parts and Accessories | GM | Keisler Engineering, Inc | Keisler Engineering - KeislerAuto.com
Old Feb 26, 2012 | 10:41 PM
  #2008
looks like a nice kit. when i did my boot, i used an fbody boot and flipped it upside down and zip tied it to the top of the shifter base.
Old Feb 26, 2012 | 10:51 PM
  #2009
kren7604's Avatar
yea that could work, id like to keep it looking origanal as much i can lol. did i read u had to get a new driveshaft made to mesh with the t-56?!
Old Feb 26, 2012 | 10:55 PM
  #2010
yeah. due to the shaft needing to be shorter and stronger. youll also need a different yoke at the tranny. and if you havent thought of it, you need to upgrade your gears to at least a 4.88 on a 30" tall tire.
