Regency RST Complete Write-Up Info
#2003
Hey guys im new here, I have an 04 Regency RST black with red stripes. Im getting ready to do a ls6 and t-56 swap, my motor is out of 202 z06 405hp
plus I installed a comp cam 224/230 113lsa .581/.588 lift cam and 918 behive springs. Here in about a month im gona have a Keisler front shift conversion installed into my t-56. once that gets done im gona start my swap
#2004
plus I installed a comp cam 224/230 113lsa .581/.588 lift cam and 918 behive springs. Here in about a month im gona have a Keisler front shift conversion installed into my t-56. once that gets done im gona start my swapby the way, sounds like a nice setup, good luck with the build.
#2005
thanks, from what iv read so far its only about 1.5 - 1.75 inches back from where my stock 5 spd is, it uses the secondary port on the t-56.. id like to keep my jumpseat and any bit i can get it forward helps lol
#2007
I was just gona slide it back to the needed position and then add black carpet to the front where the floorboard would be showing.. heres a link to the front shift conversion im thinking about T56 Front Shift Conversion Kit | Shifters, Handles & Boots | GM Parts and Accessories | GM | Keisler Engineering, Inc | Keisler Engineering - KeislerAuto.com
#2010
yeah. due to the shaft needing to be shorter and stronger. youll also need a different yoke at the tranny. and if you havent thought of it, you need to upgrade your gears to at least a 4.88 on a 30" tall tire.
