Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Regency RST Complete Write-Up Info
Old Mar 22, 2009 | 07:26 AM
  #991
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
yes you can do it yourself but on our trucks i really do recommend payin the 60 or 70 to the shop & letting them bust their *** to get em out.......definatly up to you though...either way you have to put the rear axle on jack stands...unbolt the bolts...jack the rear end up until the hanger hole lines up with the leaf spring...PITA...trust me...but i'm actually about to attempt it again because i have nothin to do today
Old Mar 22, 2009 | 08:52 AM
  #992
let me know how it goes! get tons of before and after pics! and measure before and after so we can see the exact drop before and after. Good luck!
Old Mar 22, 2009 | 10:00 AM
  #993
OneQwikSS's Avatar
lol thanks man 1qkrst did you end up cuttin into anything or how did you get the sleeve of the hanger to drop into the bracket again? that was where i got stuck last time
Old Mar 22, 2009 | 11:38 AM
  #994
RST302's Avatar
That a somewhat simple job to drop it.
Old Mar 22, 2009 | 07:07 PM
  #995
RED04REGENCYRST's Avatar
got a call from waldoch on friday and they told me the following
front air dam $425
air dam grille $90
fog lights $95
rear wing $375
Old Mar 22, 2009 | 07:41 PM
  #996
did some work on the truck today. cut the exhaust to start setting up the final fitment.
and i installed my SSR engine cover
Old Mar 22, 2009 | 08:21 PM
  #997
supenia4's Avatar
prices from waldoch are a bit steep! Must not realize how the economy is right now!
Old Mar 22, 2009 | 08:34 PM
  #998
OneQwikSS's Avatar
agreed...$95 for fog lights...that's dealership prices
Old Mar 23, 2009 | 09:51 AM
  #999
1quickRST's Avatar
No, I didn't cut into anything but it was a serious PITA and I did mine on a lift! The way the bolts go into the bracket they run into the frame, and it makes it a pain to get them out. I had to shift my rear axle all around to just barely get them out. If you attempt to do this, make sure you have a friend to help, cause one of you will have to get the bolt out while the other wiggles the axle. It took me and my bro, on a lift, about an hour to do the adjustment to the rear shackle.
Old Mar 23, 2009 | 11:46 AM
  #1000
forbes's Avatar
Originally Posted by a98ws6
Hey to those who have dropped your truck an extra inch by going to the upper hole, you say its a huge PITA doing this, but what all is involved? Can I do this by myself?
not that bad really.... drop the exhaust and un bolt the back 4 bed bolts an d put a piece od 3/4 ply wood tween the frame and the bed.... then unbolt it all.... and re bolt it up a hole...
