Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
PROBLEM WITH K&N COLD AIR INTAKE
Old Jan 10, 2006 | 10:28 PM
2004 VHO's Avatar
Unhappy PROBLEM WITH K&N COLD AIR INTAKE
I just installed a k&n cold air intake on my 2004 vho and now i am getting a little lifter chatter when i give it some gas at around 40 and 60 mph. It is making the same noise as if i was using 87 octane gas (i use 93 octane). My only other mod is a custom manaflow cat back exhaust and this started right after i installed the k&n cold air intake. Has anyone experienced this and am i damaging my engine should i remove the cold air intake
thanks
rick
Old Jan 11, 2006 | 07:08 AM
Allgonoshow's Avatar
I have a similar noise in mine after my K/N install. It sounds like a tick to me and I thought it was a header gasket leak but checked it several times an found nothing.
I put it down to just a change it the sound of the vehicle with the different filter.
I also check my timing and KR to make sure it wasn't ping as well, and that was ok.
Dave
Old Jan 11, 2006 | 07:44 AM
mwalls54's Avatar
Need More N2O Mod
I would say where its a open filter you will hear more of the motor. I have been running the fipk for a few years now on my ss and its fine.
Old Jan 11, 2006 | 08:50 AM
jus1975's Avatar
My Gmc Sierra VHO is stock and I noticed the other day that when I get on the gas hard you can hear the same chattering. Just as you said, it sounds like cheap gas. Hopefully mine will change after I change cams, rockers. springs and pushrods.
Corvette454l88
Sep 1, 2016 01:24 AM
shawn96gmc
May 17, 2016 04:15 PM
noproblems209
Aug 10, 2015 06:57 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
