lt's in maryland?
i am wondering if anyone is from maryland and has either the dynatech lt headers or the pacesetter? i need to know if i get them will i be able to pass the damn emissions test? supposodly all they do is plug something into the vehicle and if a sensor goes off you fail. any info. would be good. thanks
With all I've done to my truck I passed. Just make sure the cats are in the stock location. They didnt even get on there knee's to look under mine. I hope this helps. I allways worried about passing the emissions also but it passed with no problems.
What part of Md are you from?
They plug into your OBD-II plug under your dash to see if you have codes, readiness tests are passed, emmision related items all check out.
I have the dyna's. Passed. I have gutted cats...passed. I was loping and still passed. I have my rear o2's turned off which means I haven't passed the Catalyst Readiness test in the pcm yet...passed. You'll be fine unless there is a trouble code of some sort (which headers could give you some) and you haven't passed more than one readiness test. My **** is LOUD and they only plugged into me. I imagine I won't be so lucky one of these days.
As Breeze asks, where ya from? and Welcome aboard!
yah thanks for the help. glad to hear because i want to get the dynatech long tubes. any place you all would recommend to get these things put on at? also where did you get your headers from? also i am from the upper marlboro area in prince georges county. we will all have to get together sometime and go cruising around. although looks like you both have s/c and are out of my speed range....for now.
I bought my dyna's directly from them, I had a local guy here to me (a good friend who races monster trucks) help me pull my motor, do other work, put headers in...blah blah.
I work in Gaithersburg, live in Brunswick/Knoxville area (15 minutes) west of Frederick. Yeh soon enough we need to have a MD get together. Speed doesn't matter! Hopefully looks doesn't either!!!!LOL Hell, Breeze has both categories covered, looks and speed. He's got it all!!!LOL
I have the pacesetter lt's, no cats. i havn't been to emisssions yet,but should pass. i have never seen them use the mirror, yes all they do is plug into the port under the steering wheel. no lights and your good..
since all of you are from maryland do any of you still have your warranty on your vehicles? if so what dealership do you go to for work since you have headers and stuff? i emailed a dealer asking how leniant they were with truck with aftermarket parts they said any thing after market will void the warranty. any info?
I went to penn pontiac for my warrenty claims. they fixed everything but my rear when it took a ****. They have to prove that the parts you have,is what caused the problem. I had long tubes no cats and intake for all the other claims with out any probs.
Magnuson-Moss Warranty Act
