Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Joe Gibbs Trans Grenade
Old Nov 4, 2006 | 03:33 PM
Chris Mikolaitis's Avatar
Default Joe Gibbs Trans Grenade
Thanks everyone for the help with the clutch issue. Two days after posting it my transmission grenaded in front of Turner Field in Downtown Atlanta. The 5 speed transmission was very weak and since it is still covered under warranty with only 25,000 miles on the truck, I dont have to pay a dime to have it replaced. Or I could drop about 3,000 for a Richmond or Tremac 6 speed transmission. What should I do?
Old Nov 4, 2006 | 03:52 PM
nightrunner's Avatar
Mr. Obvious
it depends on if you want to mod the truck alot
turbogibbs on here had about 450-500rwhp on the stock 5-speed and some have problems before 400
i bet you could get a t56 from a fbody for less 3000
Old Nov 4, 2006 | 03:57 PM
EXTREME's Avatar
if money is not a big issue, i'd look for the t-56. Might want to go ahead and have the dealership replace the trans so you'll have a good one after you swap, or one to sell!
Old Nov 4, 2006 | 04:11 PM
ridnlow's Avatar
ive got a t-56 out of a 00 camaro with 37k miles that id let go for way less than 3 grand.. has a hurst shifter with it too..
Old Nov 21, 2006 | 01:00 AM
SBTork's Avatar
a T56 from the dealer out of an 04-06 GTO will run you about $2,500. Also check out car-part.com, put your zip code in and search for a trans in your local area, sweeping all the salvage yards
Old Nov 21, 2006 | 09:17 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I'd get it fixed for free anyway, at least it would be worth something in re-sale. Then swap it out.
Old Dec 3, 2006 | 10:57 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Yep, get it fixed, then swap.
FLT does hipo T56s now. Give Chuck a call and tell him your goals, he'll build you a tranny suit your needs.
Old Dec 3, 2006 | 04:55 PM
TURBO8's Avatar
Or you could buy my t56 for $2500,flex plate, clutch, hurts shifter, drive shaft and all. I am going a4.
Old Dec 3, 2006 | 06:35 PM
04GIBBS's Avatar
Default conversion
I need to find that deal on the East Coast.
flatblack83
Jan 3, 2026 07:10 PM
Turly56
Nov 13, 2015 01:00 AM
MA$TER_E
Sep 9, 2015 03:14 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
LT-1 SS
Sep 3, 2015 07:31 AM
