Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Information on upgrades for 2005 SS Silverado 2WD
Old Jun 19, 2006 | 11:30 AM
DBRASCO's Avatar
Default Information on upgrades for 2005 SS Silverado 2WD
Hey, i'm new to the forum and was wondering if you could tell me what would be the best mods for exhaust/transmission. I'm interested in the dyna long tube headers with either B&B tri flow or corsa cat back system exhaust. I'm also thinking about a shift kit for my transmission. I think the shift kit would be better than the tune for the trans. After I install my headers/exhaust/shift kit I will then be getting a custom tune. I'm located in the Dallas, TX area and I have heard alot of good things about nelson tune. My current mods are the vara ram air intake system. Everything else is stock. I know these trucks have a potential. I would eventually like to install a cam/heads but for now I will start with the flow/trans. I would appreciate any advice that you may have to offer................................Thanks DBRASCO
2005 Silverado SS 2WD.
Old Jun 19, 2006 | 01:25 PM
ZR1 DREAMING's Avatar
If you have the $$ the Dynatechs are a awesome set-up, if you'd rather spen a 1/3 of that get you some coated PaceSetters. I've got them and they are great! As far as trans mods go ahead and get the TransGo HD2 shift kit and corvette servo. I did that and had a kevlar band, hardened seperator plate, and aluminum accumulator.(and the damn thing still blew up ) Once you've got that consider a torque converter next.
For the rest of your engine mods an intake and cam would be most beneficial with a custom tune. After all that post up again with the rest of your budget.
Old Jun 22, 2006 | 12:24 AM
DBRASCO's Avatar
Default More info!!!
Thanks for the advice. Where is the best place to get a shift kit. Also what is
the best cat back exhuast. Thanks DBRASCO
Old Jun 22, 2006 | 05:34 AM
I know some of the sponsors carry them and they are also on E-bay for cheap every so often too. As far as cat-back it's up to you for which sounds best to you. Personnally I think for cat-back setups Magnaflow and Corsa are nice. But I would just get a muffler like a Hooker Aerochamber or Magnaflow welded in place of the stock one, alot cheaper that way.
Old Jun 25, 2006 | 12:23 AM
Silver LT's Avatar
Try lurking around www.silveradoss.com . You should find some guidance there.
Old Jun 27, 2006 | 09:53 PM
victoryredVHO's Avatar
i have the dynatechs for the ss (true dual cat pipes) on my vho, great fit except for the 3 cyl spark plug wire on driver side also have magnaflow silverado ss cat back also fits very well. did all the install in my driveway in one day. Bought the headers from tbryne and the exh from a dealer here in houston.
Old Jun 28, 2006 | 02:27 PM
DBRASCO's Avatar
Hey thanks for the info on the dynatechs. Did you notice a difference by installing the headers/cat back system.
Old Jun 29, 2006 | 01:49 AM
I could tell the difference more so in the mid range, i havent had the truck dynoed yet nor have i been to the track but there is an impovement also i put them on with @ 5000 miles mabey less on the truck now there is 33000 so i dont know what the gas mileage impov. is. the truck gets between 19-21 on the freeway at @ 80 mph
Rafe19
Oct 18, 2016 12:27 AM
pjb1972
Sep 17, 2015 02:06 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
85SS/85GN
Jul 22, 2015 12:48 PM
4B11T
Jul 13, 2015 03:48 PM
