Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
got a problem guys
Old Nov 15, 2008 | 04:58 PM
st_jfeist's Avatar
Default got a problem guys
my friend got a 04 rst 4.8 5 speed. has 95,000 miles on it. when i do a low pull in any gear it sputters and you can feel it missing. took out the plugs and #1 plug had unburned gas on it so i replaced it, still doing the same thing. tried using a plug wire from my 06 gmc and still did the same thing. i cant find the fuel filter to change it so it must be in the tank and i dont know if the problem might be the coil pack. help me out guys
Old Nov 15, 2008 | 05:10 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
sounds like you are on the right track...check for spark?
Old Nov 15, 2008 | 05:53 PM
st_jfeist's Avatar
afraid to check. last time i got shocked how do u check properly
Old Nov 15, 2008 | 11:32 PM
agreif's Avatar
pull the spark plug out then reattach it to the coil wire and ground the plug to the block somewhere, that's what I've done at least.
Old Jan 31, 2009 | 02:53 PM
1quickRST's Avatar
Thats how I normally do it, it really is the easiest way. you said you had an 06 gmc...if you want you could pull a coil off of that truck and swap it with the coil on the cylinder thats missing. if it starts up and runs fine I would take a good guess that you need a new coil pack for that cylinder.
Old Jan 31, 2009 | 03:45 PM
TXsilverado's Avatar
check for spark and replace the pack if there isnt any.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
