Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
06 SSS pacesetters install???
Old Jun 25, 2007 | 09:19 AM
blkssncpt's Avatar
Question 06 SSS pacesetters install???
06 SSS... ok so im expecting my pacesetter LT's to be here maybe late next week (hopefully) so my guestion is what i the easiest way to install them from the top or the bottum??? i changed my oil on sat and i checked out the area from the bottum and i didnt look like it was gonna happen from under the truck... so how should go about it??? THNX
Old Jun 25, 2007 | 04:40 PM
allballz57's Avatar
Surprisingly the hard side will be the passenger side and I'm pretty sure the best way is from the top but the trans cooler lines and ac evaporator will be in your way so you need to do a little prying and cussing.The drivers side will go in from underneath with no problem whatsoever.I did mine from the bottom because I didn't want to have to take my blower off to do the install and I couldn't believe how easy it was,just make sure you have someone there to start the bolts and line up the gasket while your laying underneath holding it up.Good luck!
Blue03sss
Mar 7, 2019 05:06 PM
Sp8s81
11
Aug 26, 2015 03:54 PM
Dirtywhite
Aug 5, 2015 04:10 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
black6spdz
Jul 16, 2015 01:32 AM
