06 SSS pacesetters install???
06 SSS... ok so im expecting my pacesetter LT's to be here maybe late next week (hopefully) so my guestion is what i the easiest way to install them from the top or the bottum??? i changed my oil on sat and i checked out the area from the bottum and i didnt look like it was gonna happen from under the truck... so how should go about it??? THNX
Surprisingly the hard side will be the passenger side and I'm pretty sure the best way is from the top but the trans cooler lines and ac evaporator will be in your way so you need to do a little prying and cussing.The drivers side will go in from underneath with no problem whatsoever.I did mine from the bottom because I didn't want to have to take my blower off to do the install and I couldn't believe how easy it was,just make sure you have someone there to start the bolts and line up the gasket while your laying underneath holding it up.Good luck!
Offroadunleashed
Jul 20, 2015 02:25 PM
