#31
My a/c worked just fine this summer, but I also upgraded to dual spal 16" electric fans. I do like the log manifold, looks like it fits much better than the SS welded one.
#32
I'm familiar with the ends you are talking about; the name brand items I've seen often seem to use those. I could see there may be some advantages to that setup but I also imagine when you are cramming the air in that it doesn't make as much of a difference from a flow perspective(compared to flow concerns N/A). You could house a small family in the area behind a GM grille so space obviously isn't much of a concern.
#34
Have to cook gumbo for the family tonight so going to just block out Friday to work on things.
I got paranoid so ordered some goodies:
TiAL MV-R wastegate and Q 50 BOV.
AEM "Failsafe" combo Boost, AFR, Ethanol content gauge
Thermal Zero "Lava" heat sheathing in various sizes
I don't mean to knock the On3 parts; they are selling what looks and feels like a pretty damn good MV-R and Q reproduction and the pair costs less than either one of the name-brand items. If you compare closely, one can easily see quality advantages to the more expensive parts. A couple are apparent in the photos. The o-ring on the On3 BOV is a bit small for the ring and was a pain to keep on there while assembling. You can see the difference in the ring that comes with each; I'll keep the TiAL version around in case I ever have issues with the part already on my hotside. Functionally the same and probably for my purposes, both would work just fine for many miles.
I'm sure if I went the distance with it I'd find other things. Let me know if anyone wants me to compare anything else before I put the On3 parts up for sale.
#35
oh gosh no, you really do need to get their recommended relays. I thought i would get away using 4 40A relays to spread the load but it just cooked them. I bought the spal relay kits on ebay for 109 each, it was more cost effective in the long run.
#36
Im running the stock spring in my wastegate (7 lbs) and it runs strong; although I do get boost creep up to about 9 Lbs, curious to know how that Tial works out.
