T6 Trick Hotside with Crossover Pipe, 60mm gate and uppipe. Southeast Michigan
Old May 10, 2016 | 03:01 PM
jscherbs's Avatar
Default T6 Trick Hotside with Crossover Pipe, 60mm gate and uppipe. Southeast Michigan
T6 Trick manifold hotside with the 60mm wastegate port.
All stainless with bellow crossover pipe.
Stainless wastegate discharge pipe and hood exit down pipe. O2 bung, stainless flanges and clamps included for gate.
Will include a 317 port matched driver side manifold as well.
$900.00
Would like to sell hot side complete. Wastegate extra.
Can add on a 60mm turbosmart wastegate for $350.00
Wastegate will only be sold after the hot side is sold. Give the hot side buyer a chance at it first.
Call Justin with questions. 734-658-2124
Attached Thumbnails T6 Trick Hotside with Crossover Pipe, 60mm gate and uppipe. Southeast Michigan-img_1038.jpg   T6 Trick Hotside with Crossover Pipe, 60mm gate and uppipe. Southeast Michigan-img_1037.jpg
Old May 10, 2016 | 04:11 PM
jscherbs's Avatar
Also to add this whole set up only had dyno time and three passes on it. The pictures above are current condition and will be how you receive the parts. I have $2000.00 into parts and labor easily and they are nearly new.
$900+ shipping is a steal for all the fab that went into this set up.
Old May 10, 2016 | 08:22 PM
jscherbs's Avatar
here are a few pics of the crossover mounted
Attached Thumbnails T6 Trick Hotside with Crossover Pipe, 60mm gate and uppipe. Southeast Michigan-img_9823.jpg   T6 Trick Hotside with Crossover Pipe, 60mm gate and uppipe. Southeast Michigan-img_1049.png
Old May 11, 2016 | 05:22 AM
jscherbs's Avatar
FYI it is twin scroll!
Old May 11, 2016 | 09:20 AM
Choda's Avatar
Good luck. This is a monster of a turbo kit
Old May 11, 2016 | 09:37 AM
GM1697's Avatar
You got a regular downpipe with it?
Old May 11, 2016 | 10:22 AM
jscherbs's Avatar
Thanks Choda!
Whats a regular downpipe? I couldn't decide where I wanted it so I just punched a hole the hood and ran it straight up. The wastegate pipe was designed so it could be cut from the uppipe and turned anyway (passenger side) someone else wanted to make their downpipe, fender exit, rear exit... whatever, you have options.
at $900 your not paying for a downpipe anyway, your paying for manifold and crossover. Anything else is a bonus and here you get the driver side mani and the wastegate discharge as well as the up pipe.
Old May 12, 2016 | 11:03 AM
jscherbs's Avatar
sold thanks PT!
rednekferlife101
May 27, 2020 04:58 PM
D3moN plz
29
Dec 19, 2017 07:18 PM
mhorn0817
May 8, 2016 10:45 PM
forklord
May 3, 2016 11:21 PM
TrickTurbo
Apr 13, 2016 09:09 PM
